Cross compiling OpenCV
885 次查看
alaam
I cross compiled OpenCV following this guide and compiled this simple program for arm. I copied the compiled files to the board (libs to `/lib` and binaries to root).
When I run the program I get an error:
./DisplayImage: error while loading shared libraries: /lib/libopencv_highgui.so.3.1: internal error
Are there any additional configurations I need to set in compiling OpenCV for it to work on IMX6 board?
Thank you
标记 (2)
594 次查看
CarlosCasillas
Hi Alaa,
The following Community document seems to be helpful for you:
Setting Up OpenCV in i.MX6 Based Boards
Hope this will be useful for you.
Best regards!
/Carlos
