I would like to change the timing configuration for the DDR3 controller on the I.MX7 chip. I could not find infomation regarding these registers.
Omar
Hello Omar,
the descriptions of the registers can be found in the Reference manual - Chapter 9 - DDR Controller and DDR PHY sections depending on which timings you want to change. Detailed descriptions of the timing parameters can be found in the JEDEC specifications.
Jan
Hi, Jan:
Could you provide me the reference manual? Or just send me a link to it?
I have others, like: power consumtion measurement, Hardware Development Guide, etc...but not the reference manual your pointing out.
Omar
You can find it here.
Jan
Hi Omar
please use ddr init tool on
i.MX7D DRAM Register Programming Aid
