Cannot run bluetoothd on imx6ul
853 次查看
tsung-chihwang
My current Linux BSP version is 3.14.38.
I am trying to verify an USB BT module on imx6ul.
1. I added this line to conf/local.conf, then used "bitbake core-image-minimal" to build code.
    IMAGE_INSTALL_append = " bluez5"
2. Finally, I put the contents of built rootfs to my current rootfs.
3. However, I got an error while running bluetoothd.
    Below is my error log.
root@imx6ulevk:/usr/lib/bluez5/bluetooth# ./bluetoothd -d -n
bluetoothd[581]: Bluetooth daemon 5.28
D-Bus setup failed: Failed to connect to socket /var/run/dbus/system_bus_socket: No such file or directory
bluetoothd[581]: Unable to get on D-Bus
Could you tell me how to fix this issue?
标签 (4)
标记 (1)
650 次查看
igorpadykov
Hi Tsung-Chih
one can try steps described in Linux Guide on murata support portal for i.mx wifi,
bluetooth  solutions
wireless.murata.com/eng/products/rf-modules-1/wi-fi-bluetooth-for-freescale-i-mx.html
Linux NXP software is described on link
i.MX Software|NXP
If used bluetooth module is different, it is necessary to install driver for that module,
it should be provided by vendor of that module
650 次查看
tsung-chihwang
I think the root cause is dbus-daemon is not running.
However, I got an error again on enabling it.
root@imx6ulevk:/etc/init.d# ./dbus-1 start
Starting system message bus: start-stop-daemon: unknown user messagebus dbus.
