Cannot allocate a DMA buffer in kernel module
1,286件の閲覧回数
quentinchang
Hi Sir,
I try to allocate a buffer in my kernel module but it failed.
Below is my testing kernel module codes.
    void           __iomem *dma_vbase = NULL;
    unsigned long  dma_pbase = 0, size = 0x2000000;
    unsigned long  pbase = 0;
    pbase = isa_virt_to_bus(high_memory);
    dma_pbase = pbase;
    dma_vbase = ioremap_nocache(dma_pbase, size);
    if (dma_vbase != NULL) {
        pr_info("dma_vbase: %p\n", dma_vbase);
        iounmap(dma_vbase);
    pr_info("--> dma_vbase: %p, dma_pbase: %lx, allocated size: %lx\n", dma_vbase, dma_pbase, (unsigned long)size);
Output:
------------[ cut here ]------------
WARNING: CPU: 0 PID: 638 at arch/arm/mm/ioremap.c:301 __arm_ioremap_pfn_caller+0x184/0x1a8()
Modules linked in: linux_kernel_bde(PO+)
CPU: 0 PID: 638 Comm: insmod Tainted: P           O 3.14.52-1.1.0_ga #4
[<80015788>] (unwind_backtrace) from [<80011858>] (show_stack+0x10/0x14)
[<80011858>] (show_stack) from [<80765d38>] (dump_stack+0x7c/0xbc)
[<80765d38>] (dump_stack) from [<80032f60>] (warn_slowpath_common+0x70/0x8c)
[<80032f60>] (warn_slowpath_common) from [<80033018>] (warn_slowpath_null+0x1c/0x24)
[<80033018>] (warn_slowpath_null) from [<8001b504>] (__arm_ioremap_pfn_caller+0x184/0x1a8)
[<8001b504>] (__arm_ioremap_pfn_caller) from [<8001b574>] (__arm_ioremap_caller+0x4c/0x54)
[<8001b574>] (__arm_ioremap_caller) from [<7f001b60>] (_alloc_mpool+0x50/0x11c [linux_kernel_bde])
unwind: Index not found 7f001b60
---[ end trace 11aa9be18d33025f ]---
--> dma_vbase:   (null), dma_pbase: 7f800000, allocated size: 2000000
The function __arm_ioremap_pfn_caller() returns NULL.
I am not familiar to i.MX6 CPU.
Does any one can provide a way to allocate a DMA buffer in kernel module ?
Thank you very much!
4 返答(返信)
992件の閲覧回数
igorpadykov
Hi quentin
one can try to set sufficient memory in cma (defined in imx_v7_defconfig),
also is board have sufficient free memory (>32MB as requests your code)
992件の閲覧回数
quentinchang
Hi Igor,
Thanks for your reply.
I think cma is configured in kernel defconfig.
CONFIG_CMA_SIZE_MBYTES=320
CONFIG_CMA_SIZE_SEL_MBYTES=y
I found the function __arm_ioremap_pfn_caller() return NULL in below code block.
* Don't allow RAM to be mapped - this causes problems with ARMv6+
if (WARN_ON(pfn_valid(pfn)))
return NULL;
Do you have any suggestion to this problem ?
Thank you very much.
Quentin
992件の閲覧回数
igorpadykov
Hi quentin
please post this on kernel.org mail list
992件の閲覧回数
quentinchang
Hi Igor,
Got it. Thank you!
Quentin
