Can the iMX8M support the CS42888 audio codec in yocto linux, or is support only for SOCs with ESAI support at the moment?
The device tree file says to specify "The phandle of the i.MX SSI controller", but the variable is "esai-controller"...
The iMX8M-Mini has "one SAI with 4 TX and 4 RX lanes" that seems a good fit, can you just pull down the 2 unused pins?
Nathan
已解决! 转到解答。
Hi Nathan
you are right currently it is supported only for SOCs with ESAI, no support for i.MX8M.
Hi Nathan
