Hello sir:
I want to use iMX7D (MCIMAX7D5EVM10SD) and 64MB (512Mbits) LPDDR2, but I know from the iMX7D manual that only 512MB to 2GB LPDDR2 density is supported. so can I use a 64MB LPDDR2 for iMX7D?
Thanks a lot!
Solved! Go to Solution.
Hi hefeijiutian
one can check if memory parameters fit to conditions described in
Table 9-1. DDRC feature summary :
Column size of 8-12 bits
Row size of 11-16 bits
i.MX 7Dual Applications Processor Reference Manual
Hi hefeijiutian
Thanks a lot sir!
