hi all,
i am new to imx. i am using imx535qsb board for an camera interface application for the i had downloaded the mmcodecs from the frescale website it is debian package. i need to cross compile the codecs for my imx board. can any one tell me how to cross compile the gstreame for imx board
Thanks in advance
Solved! Go to Solution.
Start a new topic, for 1080p enconding on imx53, and place the link over here.
Let´s close this thread.
It will be easier to get more help with the correct subject.
Try to start new topic with a command line, and describing your environment (kernel version, board)
Freescale does not provide source code to the codecs, so you don't need to compile them. Just prep and deploy that package with LTIB:
./ltib -m prep -p fsl-mm-codeclib
./ltib -m scdeploy -p fsl-mm-codeclib
You will need to build Freescale's plugins for GStreamer, as well as GStreamer itself. This is done with LTIB also:
./ltib -m prep -p gst-fsl-plugin
./ltib -m scbuild -p gst-fsl-plugin
./ltib -m scinstall -p gst-fsl-plugin
Regards, Clay
This is not entirely true. In the IMX_MMCODECS release package there's both Debian binaries but also sources for LTIB. In order to run steps mentioned above, these sources (tar.gz files) need to be stored to /opt/freescale/pkgs (Local Package Repository for LTIB).
Check the readme.txt file and codecs user's guide in the release package for more detailed info.
hi Vladan Jovanovic
you are right in the imx_mmcodecs they provided the sources for LTIB. i've untared the sources,and in the user guide they ask to install the <ltibrelease> but there is no such file and also in readme.txt they dint provide the direct information. in the downloaded file they provided only debian binaries. sorry asking same thing again and again can you provide me the procedure to configuring for cross compiling the source
NOTE:
there is no such folder LTIB in the downloaded source
and one doubt imx board must have the ubuntu os for this cross compiling?
Shanmugam.
You must make a difference between Linux HOST used for building i.MX Linux BSP and codecs from sources (cross-compiling) and Linux TARGET, which is i.MX53-based device (in your case i.MX53QSB). Linux HOST is usually PC.
On host it's recommended to run Ubuntu Linux (as Freescale is testing BSP releases on Ubuntu) to install LTIB (which is build system for i.MX Linux BSP) and multimedia codecs for cross-compiling.
On target (i.MX53) you can run either Ubuntu image or Linux BSP that you have built (cross-compiled) on the HOST PC.
hi Vladan Jovanovic
i had compiled the gstreamer and ported on the target board when i supposed to run the command gplay [file name] it shows the error
Physical memory allocation error!
[ERR] mem allocation failed!
Debug: Allocation of the Frame Buffers Failed
Error: fatal error
Thanks in Advance,
shanmugam.
hi Vladan Jovanovic
here is the log file
LOG FILE :
U-Boot 2009.08 (Sep 24 2011 - 22:18:53)
CPU: Freescale i.MX53 family 2.1V at 800 MHz
mx53 pll1: 800MHz
mx53 pll2: 400MHz
mx53 pll3: 432MHz
mx53 pll4: 455MHz
ipg clock : 66666666Hz
ipg per clock : 33333333Hz
uart clock : 66666666Hz
cspi clock : 108000000Hz
ahb clock : 133333333Hz
axi_a clock : 400000000Hz
axi_b clock : 200000000Hz
emi_slow clock: 133333333Hz
ddr clock : 400000000Hz
esdhc1 clock : 80000000Hz
esdhc2 clock : 80000000Hz
esdhc3 clock : 80000000Hz
esdhc4 clock : 80000000Hz
nfc clock : 26666666Hz
Board: MX53-LOCO 1.0 Rev. A
Boot Reason: [POR]
Boot Device: SD
I2C: ready
DRAM: 1 GB
MMC: FSL_ESDHC: 0,FSL_ESDHC: 1
In: serial
Out: serial
Err: serial
da9052_i2c_is_connected - i2c write success....
Serial reinitilized!
Net: got MAC address from IIM: 00:04:9f:01:dc:48
FEC0 [PRIME]
Hit any key to stop autoboot: 2 1 0
Unknown command 'mem=64M' - try 'help'
FEC: enable RMII gasket
PHY indentify @ 0x0 = 0x0007c0f1
Using FEC0 device
TFTP from server 192.168.0.50; our IP address is 192.168.0.150
Filename 'uImage'.
Load address: 0x70800000
Loading: * FEC: Link is down 7809
done
Bytes transferred = 3121348 (2fa0c4 hex)
## Booting kernel from Legacy Image at 70800000 ...
Image Name: Linux-2.6.35.3-g4b94fa6-dirty
Image Type: ARM Linux Kernel Image (uncompressed)
Data Size: 3121284 Bytes = 3 MB
Load Address: 70008000
Entry Point: 70008000
Verifying Checksum ... OK
Loading Kernel Image ... OK
OK
Starting kernel ...
Éñ)Áæ)Éùñ$æ'ÑÌÞÖÑ.Âñ¡äX;Ù!É!ÉÑ/4ç)1)å/4ç)1)éæé×Üöäùé&ä6ÉE.ØØ î)ÉùñÆæÌ/à$ôÆ4Ex
ä))á) )ÉEÐ.1'ù))É4é×/ÜØ1äÉöÉÉ É!)$ô ÔÑÎ0ÑEÑDÌvÀE¥¡ e%¥@1E»@¥\ á¡YFÌ=à¹$ôY
QÖÀ&ÔÁ))Ï )/' ù)ù4 'æ9ÖÖ fÞ1îÉÉùñÔE &éÅ'Ø6Þá4'ÎØ',w)ôä)Àqùñ á
É Éñ9ÆXzÁ4XØèÉá)& ! f××XîÑ Éñ9×Þöä)!Éùñ6XØèÉép'ÁÁÉñ)Ñ(Ü1É á
)ÖçÄÖÔÐÈAß !é0'ÉéùÉùáÉÉÑQ(ÐÐ ÈÉ á)!á(0è 4XØèÉöÉ!) ÙépÐ9Ñá!_×,wÑ!
]ßñ)öÜÆÉáY×Ø4ØÉ!ÉöÞ×/žÑñ9ô,.È (ù! á 9)ÑQF'ÎîeDpÑ1äñ)á4×××XïÈÆ×]wÉÑQ
×,7ù¹ÆÔÈØ×Þ×,è!ÉéÁÄÑÎé^×/.Üöñ)éæ.Ü Ñé&æÑwðyæÑàÑ&äÑÎwðyæÑ'ô &æÑwðyæÑ=ä¥ÔäÎ
éq$ÔÖæÎ=ôÙô..ÑñÉ!éôÑÜaÑñù×]zÀùù!éö,/,Þ Þ1ùù!é$æÑwðqäÑ'ö}×××.Ñ/4ç)1)ùä,Þqßù!ù×
_cçáæ×××ØÙ ä9ép(!"ºÁÁÆ á)Ö/Ü6ÉÑfìÑÜÆÉÑYÌ.À &Ä\<è)ÉÔÁ )ñ!É4XØèÉ×XÞèÀ¡ á
)Ô/Ü6ÉÑgñEÜÆÉÑÑFÀ$öæ\<è)ÉÖÁñù!)é4XØèÉ×XÜèÀ¡ á)Ô/Ü4ÉÑ'ñ±EÞÆÉÑFÀ æ4Æ\>è)ÉÔÁ)
éùÉÑ'² î¡ÔÐ èù! áép'ÉéùÉÑQ'ð &6×Ñ'ð &4È0ì Éá á)áYG'Ìv×&))1)!á
FÑ ÐÉ9Áé)éé0)6ä!) á6×.ÜïÉáÖ×,7ßÉÆ×X>ß)!ÑÔÁÀd/1Ç!ùgàÁ1111QÈ0ð1111 D
Ðd;À]%ÑÁÀD,6ðé gàÁ111Q0ð111)dÐäÙ]AÑeD0À('DÀÑf|ÎÉÖ0àY0ð11)DÐQg'%ÑÁÀd/7Ááá
ù$F|ð¡QÈ0ð1!DÐ ôÆQÐQ ÀÄ××/7ÉéGàÁÁY0ðÁÄdÐ'@eEYÌ ÀÙé DÏ àÁ9æ.àYÈ0ðÁ
DÐdÎ %ÑÁÀd7ß!)á)$F|ï1QÈ0ð9æ.àDÐYf;ÀeEQ ÀdÑ]wÑ!&f|ðY0ðÁ64dÐô$Ù]AÑeD0ÀdÞ
¡)Á!$f|ð44YÈ0ðÁ4DÐÁ$æÑ]AÑed0ÀDÜ! ! $F|ðäQÈ0ðÁ$ØÎ0àdÀæÙ]AÑeDpÔ)E
Ñ(1Üá éÄÈÈ/ áÉ9ñé4&ÄÈÞÆÉéÖÑÎ.Àe%×ØeÉ!éÆÐP)éÆß!)éÖÁÉ) ÁÉ á$é()ÀEé
á)é)ñ! !ÉùññÖÁe)Ä )!Æ.œÅ!Éùñö.ç! áá)!4)ç×Þ ÈÉ á)!ñÔÁ¹¥Þaß)6! á
á)!é6)çÄ.œÅ!Éùñ×Þ ÈÉ á)!ñÔÁé)Ö('Ñ4äÔÁÁé()ÔèÁ!9 )éÈ0'0²¢² ²ºîÑ!É á
ÉÑ)!éÈ0'0å)(0äáÉ6)É á6×Þ×,Á!ÔÖÔQÈ0ð)6æØØ0àE^zÑùñöYFéöQEG×/Ø×Þ×.7!!ÉéÁÖ F
1Ü á)!éðùñùá)ÑÙ\××/Ü È)ééÉÆ./6Ç)ÔÁ áÉ !Éñ9Ä,wÁÉÄ××^/ÜqññÅæ'Ì
ù9ùé%Ô ÐaÑéÄô&ÑÁàÉ!ù)×X|ôÄ..0éá!ÑÑFÌ''ÀeÉñÉé)éÑÙfáeDðù)ñ!é4XØèÉ×XÞèÀ¡ á
)Ô/Ü6ÉÑQ'äedð))Ï ()!Éñ9ôÉ!)&/,.1æ4]1æ)ñÉÑñßÙéðä)9)á !ùÑÑ\Þ1À±)ÉùñäÑ'ÿ) %Ï $)
9É!))!ù!ùùáæX7ÑáÉäÖÁÑñÖ`EE¥ ùùáÑQFÌ8À]EP0ðÁÄÆÔÁ)('À¥PB1éÈðùeÉ%ÔQ$É%ÔY&É%ÖÑ
Q_ØÉ.×XqÈù)×]zQü))ÑÑç&),/6çÉùñ&æÑÔÔÐÉ%ÖY&É%ÔQ$É%ÖÙQ_çý ××Ø×)××)×]zYü)Éñ96 (
'ÑPPéÈðÁé( é% ɲºîÑ!É áÉÑ)!éÈðé f9çö Ù))ù)éðé F9çô Ù))ù)éÈð
ÆÉùÑÙ\yÉ !)6á Ä&»ïÙäY\zÀÖÁ'e¥¢@)É!)é×]zÑ áÉÑ)!éð
)) á)Ôé%Ð !
é( É1)Æ××XbÉ!á&Ô1ìÉÉùñÑQfÑ'À!ÔÁQÉ%ÖQ$É%ÔY&É%ÖQ$É%ÔY&É%ÖQ$É%ÔY$Ï!)ÖÐ!ÀY$É%ÖQ$É%ÔY$
É%ÖQ$É%ÔY$É%ÖQ&É%Y\K×/Ð 1)4))ñÆÁÉä×/6Ç)Þ ñù)×X{ÉÔ×XaØ)!ö)(ÈÉ1)æÜ ÙÁ)6ÔÔÐaß !
ép(Ü ÙÁ)6××ØÈaß !á/vÉö)(Î)ñ!Éùñ×Ü éñ 1 Éá á)Ä/1À¡ù×XyÈ9 )
Ä×]7Ñ! !ÉùñéÈpÔ×_ ßñ)Öä/×ØöÑùñ.1ìÉ)ôÜ Ðù!ÉÙ\0Þ$,Á1 Éá á)äÞ Ç)! É
ñ××X,1YJvÉ )4.4Ïù)6×.ÜïÉáÆùÆ»Ü0Äá)ô)(Áñ!ÄÁ)Öæ/×ØöÑùñù)Æ×$œ@œ ñ!ÄùÖ)éÈ
p Ü!&)é ÉñÄÁ)ô/vÉÔä/×ØöÑùñù)ôù)á!Æ×]Ù1À¡ùÔ)é0G.wß9ô)(Çùñ1É96Áù)á!$,ä)éù1)!Ñ
ÔÁùÅ($ù)Ðé)(Àå($ù))ÔA?ù ¥(ÁÁùù)ô×.ß1$.wß94,6ÏæÜ Ðù!ôÞ È)1É)ä/×ØöÑùñéÈ0Ð9è
Æ! fØèßù)ÆÁ)éÄù9)!Á)é0÷)(Ðù!6,4ÏépÐ(&ù))ÖA?)ÔÐ&? E¥Ðé)(Á!é(È)1É
)6,4ÏépÐ(&ù))ÖA?9%((!(é0ÿéù)Ñ^1ÏÉ!))!æ×,/Ññ!)1 )ÄÜ6ì)Ô1éðéù)Ñ^1ÏÉ!))!
æ×./Ññ!)1 )ÆÜ6ì)×/Øÿéù)Ñ^1ÏÉ!))!æ×./È)1É)ÆÜ6ì)ÖéÈðÈ ÉÖ$ô)ÎØ)×Üé.×.Øö
É!Ö6ä&) !4))ñäÑÁä)9)á !ùÑ( ñÔ$ö (Ô=À±ÔÑQfàY)Á!4Q)Þùé áÔÁæ)9)á !
ùÑ( ñÖ$ô (Î=À±ÔÑQFàY)Á!6Q)Üùé áÔÁä)9)á !ùÑ( ñÔ$ö (
ÔÎ=À ô$ÖÖÑÙFÌ0àÔ)Á!44Y)Üùé áÖÁä)9)á !ùÑ( ñÔ$ö ('Ï áœ$ÖÖÑÙFÌ0àÔ
)Á!$ôöÖY)Þùé áÔÁæ)9)á !ùÑ( ñÖ$ô (Ô'Ï áÔÑÙf'àÔ)Á!4Q)Þùé á
ÔÁæ)9)á !ùÑ( ñÖ$ô ('Ï áÔÑÑf'àÔ)Á!4Q)Þùé áÔÁæ)9)á !ùÑ( ñÖ&ô (
Ö'Ï áÔÑÑf'àÖ)Á!&öÔQ)Þùé áÔÁä)9)á !ùÑ( ñÔ$ö (=À &ÔÑÙF'àÔ)Á
!Q)Þùé áÔÁæ)9)á !ùÑ( ñÖ$ö (Ô=À &ÔÔÑÙf'àÔ)Á!ÔQ)Þùé áÔÁä)9)á !
ùÑ( ñÔ$ö (Ô0ö$ÖÑÑF'àÔ)Á!6Y)Üùé áÖÁä)9)á !ùÑ( ñÔ&öÉ()Ùåé
(Ô!ôÔÖÑFï¥Y)Á!&ÔY)Üùé áÖÁä)9)á !ùÑ( ñÔ$öÉ()Ùå %ÖÏ éÔÑfï¥Q)Á!
4Q)Þùé áÔÁæ)9)á !ùÑ( ñÔ$öÉ()Ùå)Ô('ö$ÔÔÑfàQ)Á!ÔQ)Þùé áÔÁæ)9)á !
ùÑ( ñÖ$öÉ()Ùå ¥¡²EEQFàÖÑÑF'àÖ)Á!æôÔY)Üùé áÖÁ %Ô4Ñ\ìÑ(ä)9&) !é 9
gÐ î)Éùñù)!éð)).!%QÉ9Ög;ð1ÖÁ))é2Ö1ÏÔG;ðÁäÔÁ))"Ô1ÏÖg;ðÁ0àeDp& ) f& é%Ð &)
9Ög;ðÁÖ0àedð)) fÖ1ÏÔG;ðÅ$ÔÁ)) "Ô1ÏÖg;ðÅæÖÁ)) éÅÐ &)9ÖG;ðÅ0àeDp& ) fCJ1ÏÔG
;ðÅÔÌ0àeDð$ ) FC J1ÏÖg;ðÔÁÀE¥¥@¥(Ð $)9Ôg;ð1ÔÁ))) &)9Ög;ð ÖÁ)))ÖÎ
&)9ÖG;ð)ÖÁ)))Ö,7ÀåG;ðÔÁ))()Ô.7Àåg;ñÖÁ)) 2¥Åeá !)ÖÔ.7Àåg;ñ¡ÖÁ)) Éá É$),.4ßñ
YÖ,7ÀåG;ðÔÁÑ)ùé.w×ÔFàÖÁ)) éÅÐ ùE¥³ Ô×,1öÎÿ ÁÄÆÑ'ØÔävØœÑÁ!1 ñ)!ÄÖ]wé
Á4é×/,ÁÉ!)!))ÆÜ6ì)æ),ÜÞ4ßñæ/ääÑÁá))!ùù!ÁÑÙXÜ1À¹)$æÑQü) %Ï $)9É!))!ù!ùùáæX7Ñ
áÉ6ÔÁá))!ùù!ÁÑYÐ&À!)1É).Çùññ)!ÉùñÖ×XïÁ9)×]zÑ áÉÑ)!éðá))!ùù!ÁÑQÐ$ÀùÙ)!Æ×X>É×
]zÑ áÉÑ)!éÈð'9É!ÁÉñ9Äù4××ØÙÞ×/ÜØ1ÀeÁù /4Ù) ÖÁ) %Ï $)9É!))!ù!ùùáæX7
ÑáÉ&ÔÁ FÜ×/œÅ4XØèÉ×XÜèÀ¡ á)Ô/Ü6ÉÑYFä¡EÜÆÉÑFÀ¡æ\>è)ÉÔÁ(%É! áÉÁ)!×XÜ
èÀ¡ á)Ö/Þ4ÉÑfèÁEÞæÉÑfÀ æ4Æ\>è)ÉÖÁ(%ÆÉñ!×XÜèÀ¡ á)Ö/Þ4ÉÑfèÁEÞæÉÑYfÀÁ$\
<è)ÉÖÁ(%Ï ÁÆ á)6.4Ï))!Ñ,ÞöÁáÉÁ)!$Æ\6Þ!$ÆÑÁ(%æ)ñù&)9É!))!éÈð) F
tÁÁÆ á)Ö/Ü6ÉÑfìÑÜÆÉÑFÀ¡æ\>è)ÉÔÁ)!¥ÌÑ!)×XÜèÀ¡ á)Ô/Þ4ÉÑFîÑÞæÉÑfÀ¡ä\<è
)ÉÖÁ) %Ï &)9É!))!ù!ùùáäX7ÑáÉÖÁ$é(Ï $)9É!))!Ô!Ä ñù!Ö×.9Ø)ñÖÁ$é(Ï &)9É!))!ÆÆ ñ
ù!Ö×,9Ø)ñÔÁ&é(Ï $)9É!))!Ää(Ö÷èq\0ÇÙÁ ññ)áÄ ñù!Ô×.9Ø)ñÔÁ)Ô,1À!É1)Ô×.9Ø)Ä××Xb
É!épÖöÁ!Éé×/1äÔÔXïÁ9)é)ñ!æÜ
)) á)ÑQü é2,Þ4î)Ö×,9Ø)Æ××XbÉ!éðç! é
/œß9 !Éñ9ÆÞ4ì)Ö×,9Ø)Æ××XbÉ!éð)äÜ1áÆÞ4ì)Ö×,9Ø)Æ××XbÉ!éðY]Þ àÉé ÉéðÙÁù .
/,Þé.Ü1?ù)éð 1É(Ô ÈÉ1)Ö×,9Ø)Æ××XrÉ!éðÑñÔÐ ))Ì) ))ñÉÆÞ4ì)éð 1É(Ö )E%ÈÉ1)
Ô×.9Ø)Æ××XbÉ!éð1ÅÖ1À±)Éùñ$äÎ/ÀAæÖP ÉxÔÀÖÌ0à¹J1ÈÔXzØ×Ø/QüÙ9éñÉ×XÞ Æ))ñ6)!ÄùÖÁ
Áá9ÑÖöÉ!äÜ ç!!ñ9ÑÙqÜ9ÉÖÁÇÉ!ù!)1Ñ.Ü6ì)Ä××XrÉ!ñÔÁÑù4Á)!)á)ä××^ ä)9É!))!ép4ß6Á)
!)á)Æ.0ÈáÉñ)$)9É!))!éðÑù6Á)!)á)6.8À)9É!))!,1Î )á!ÉÖÁä)9)á !ùÑÙ.1èÁ
È/4èÁä×4È)ñ!É1É)éÈðÉ4)!!Éñ9á(Ð ÈÉ1)ôÉááæ×/Ä)Ö×XaØ)!éðÙÁ1ùé/1è)ÑQ×.1À!ÔÔÑX ¥
Ñ))( YüÙÁù)^9ÀeÁù)^9ô4»Áyñ)áÜ1Á!ÉÄ»óá)!ÔÁÙÁù)^9ÀeÁù)^9ô4»Áqñ)áÜ1Á!ÉÖñÉñÉ!É á
ÉÑ)!ÔÁùñùá)ÑÙ^/4èÁÉñ9Æù4××/Ü Ì é)$/.,1äÄ./6Ç)ÔÁÙÁ1ùé/1è)ÑQ×.1À!ÔÔ)( ÙÁåPÿÙ
Áù)^9ÀeÁù)^9ö6»Áqñ)áÞ1Á!ÉÆ»ãá)!ôÖÁÙÁù)^9ÀeÁù)^9ö6»Áqñ)áÞ1Á!ÉÖñÉñÉ!É áÉÑ)!öÔÁ
ÙÁ1ùé/1è)Ñ×7ß!)6!éðÙÁù)^9ÀeÁù)^9ö6»Áqñ)áÞ1Á!ÉÆ»Ü0Äá)!ÖÁÙÁù)^9ÀeÁù)^9ö6»Áqñ)á
Þ1Á!ÉÖñÉñÉ!É áÉÑ)!ÔÁ')É áÑQÐ ñ!)ñ áÔ)(ÖÀ!É1)éðÙÁÉñ!) !ñ&/œñeÁ
Y\zÀe¥ÖQ0ð)4äØØ0àE4æ ÔÙfÑ×Ü ÁäÞ1É á)Ñÿconsole [ttymxc0] enabled, bootcons
ole disabled
console [ttymxc0] enabled, bootconsole disabled
mxcintuart.1: ttymxc1 at MMIO 0x53fc0000 (irq = 32) is a Freescale i.MX
mxcintuart.2: ttymxc2 at MMIO 0x5000c000 (irq = 33) is a Freescale i.MX
mxcintuart.3: ttymxc3 at MMIO 0x53ff0000 (irq = 13) is a Freescale i.MX
mxcintuart.4: ttymxc4 at MMIO 0x63f90000 (irq = 86) is a Freescale i.MX
loop: module loaded
MXC MTD nand Driver 3.0
i.MX GPMI NFC
vcan: Virtual CAN interface driver
Freescale FlexCAN Driver
FEC Ethernet Driver
fec_enet_mii_bus: probed
ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
fsl-ehci fsl-ehci.0: Freescale On-Chip EHCI Host Controller
fsl-ehci fsl-ehci.0: new USB bus registered, assigned bus number 1
fsl-ehci fsl-ehci.0: irq 18, io base 0x53f80000
fsl-ehci fsl-ehci.0: USB 2.0 started, EHCI 1.00
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 1 port detected
fsl-ehci fsl-ehci.1: Freescale On-Chip EHCI Host Controller
fsl-ehci fsl-ehci.1: new USB bus registered, assigned bus number 2
fsl-ehci fsl-ehci.1: irq 14, io base 0x53f80200
fsl-ehci fsl-ehci.1: USB 2.0 started, EHCI 1.00
hub 2-0:1.0: USB hub found
hub 2-0:1.0: 1 port detected
usbcore: registered new interface driver cdc_acm
cdc_acm: v0.26:USB Abstract Control Model driver for USB modems and ISDN adapter
s
Initializing USB Mass Storage driver...
USB Mass Storage support registered.
ARC USBOTG Device Controller driver (1 August 2005)
mice: PS/2 mouse device common for all mice
input: gpio-keys as /devices/platform/gpio-keys/input/input0
MXC keypad loaded
egalax_ts 2-0004: request gpio failed:-16
egalax_ts 2-0004: egalax_ts: failed to read firmware version
egalax_ts: probe of 2-0004 failed with error -5
p1003_fwv33 2-0041: couldn't read panel infomation.
p1003_fwv33: probe of 2-0041 failed with error -5
DA9052 TSI Device Driver, v1.0
da9052_tsi da9052_tsi: da9052_tsi_init_drv: error getting regulator VDD_A
input: da9052_tsi as /devices/virtual/input/input1
TSI Drv Successfully Inserted da9052_tsi, 4-wire
input: da9052-onkey as /devices/platform/imx-i2c.0/i2c-0/0-0048/da9052-onkey/inp
ut/input2
mxc_rtc mxc_rtc.0: rtc core: registered mxc_rtc as rtc0
i2c /dev entries driver
IR NEC protocol handler initialized
IR RC5(x) protocol handler initialized
IR RC6 protocol handler initialized
IR JVC protocol handler initialized
IR Sony protocol handler initialized
Linux video capture interface: v2.00
OVIYA init_camera_struct 2597
OV5640***: ioctl_s_power on=1
Setting mclk to 24 MHz
ov5640_init_mode:write frame_rate=1, frame_rate=0
ov5640_init_mode:write frame rate=1, modee=0
OV5640***: ov5640_init_mode
OV5640****: write reg=3103 val=11
ov5640_write_reg:write reg error:reg=3103,val=11
OV5640****: read reg=3103 val=11
OV5640****: write reg=3008 val=82
ov5640_write_reg:write reg error:reg=3008,val=82
OV5640****: read reg=3008 val=2
OV5640****: write reg=3008 val=42
ov5640_write_reg:write reg error:reg=3008,val=42
OV5640****: read reg=3008 val=42
OV5640****: write reg=3103 val=3
ov5640_write_reg:write reg error:reg=3103,val=3
OV5640****: read reg=3103 val=3
OV5640****: write reg=3017 val=7f
ov5640_write_reg:write reg error:reg=3017,val=7f
OV5640****: read reg=3017 val=7f
OV5640****: write reg=3018 val=fc
ov5640_write_reg:write reg error:reg=3018,val=fc
OV5640****: read reg=3018 val=fc
OV5640****: write reg=503d val=0
ov5640_write_reg:write reg error:reg=503d,val=0
OV5640****: read reg=503d val=0
OV5640****: write reg=3034 val=18
ov5640_write_reg:write reg error:reg=3034,val=18
OV5640****: read reg=3034 val=18
OV5640****: write reg=3035 val=11
ov5640_write_reg:write reg error:reg=3035,val=11
OV5640****: read reg=3035 val=11
OV5640****: write reg=3036 val=48
ov5640_write_reg:write reg error:reg=3036,val=48
OV5640****: read reg=3036 val=48
OV5640****: write reg=3037 val=13
ov5640_write_reg:write reg error:reg=3037,val=13
OV5640****: read reg=3037 val=13
OV5640****: write reg=303d val=32
ov5640_write_reg:write reg error:reg=303d,val=32
OV5640****: read reg=303d val=32
OV5640****: write reg=3108 val=1
ov5640_write_reg:write reg error:reg=3108,val=1
OV5640****: read reg=3108 val=1
OV5640****: write reg=3630 val=2e
ov5640_write_reg:write reg error:reg=3630,val=2e
OV5640****: read reg=3630 val=2e
OV5640****: write reg=3632 val=e2
ov5640_write_reg:write reg error:reg=3632,val=e2
OV5640****: read reg=3632 val=e2
OV5640****: write reg=3633 val=23
ov5640_write_reg:write reg error:reg=3633,val=23
OV5640****: read reg=3633 val=23
OV5640****: write reg=3621 val=e0
ov5640_write_reg:write reg error:reg=3621,val=e0
OV5640****: read reg=3621 val=e0
OV5640****: write reg=3704 val=a0
ov5640_write_reg:write reg error:reg=3704,val=a0
OV5640****: read reg=3704 val=a0
OV5640****: write reg=3703 val=5a
ov5640_write_reg:write reg error:reg=3703,val=5a
OV5640****: read reg=3703 val=5a
OV5640****: write reg=3715 val=78
ov5640_write_reg:write reg error:reg=3715,val=78
OV5640****: read reg=3715 val=78
OV5640****: write reg=3717 val=1
ov5640_write_reg:write reg error:reg=3717,val=1
OV5640****: read reg=3717 val=1
OV5640****: write reg=370b val=60
ov5640_write_reg:write reg error:reg=370b,val=60
OV5640****: read reg=370b val=60
OV5640****: write reg=3705 val=1a
ov5640_write_reg:write reg error:reg=3705,val=1a
OV5640****: read reg=3705 val=1a
OV5640****: write reg=3905 val=2
ov5640_write_reg:write reg error:reg=3905,val=2
OV5640****: read reg=3905 val=2
OV5640****: write reg=3906 val=10
ov5640_write_reg:write reg error:reg=3906,val=10
OV5640****: read reg=3906 val=10
OV5640****: write reg=3901 val=a
ov5640_write_reg:write reg error:reg=3901,val=a
OV5640****: read reg=3901 val=a
OV5640****: write reg=3731 val=12
ov5640_write_reg:write reg error:reg=3731,val=12
OV5640****: read reg=3731 val=12
OV5640****: write reg=3600 val=8
ov5640_write_reg:write reg error:reg=3600,val=8
OV5640****: read reg=3600 val=8
OV5640****: write reg=3601 val=33
ov5640_write_reg:write reg error:reg=3601,val=33
OV5640****: read reg=3601 val=33
OV5640****: write reg=302d val=60
ov5640_write_reg:write reg error:reg=302d,val=60
OV5640****: read reg=302d val=60
OV5640****: write reg=3620 val=52
ov5640_write_reg:write reg error:reg=3620,val=52
OV5640****: read reg=3620 val=52
OV5640****: write reg=371b val=20
ov5640_write_reg:write reg error:reg=371b,val=20
OV5640****: read reg=371b val=20
OV5640****: write reg=471c val=50
ov5640_write_reg:write reg error:reg=471c,val=50
OV5640****: read reg=471c val=50
OV5640****: write reg=3a18 val=0
ov5640_write_reg:write reg error:reg=3a18,val=0
OV5640****: read reg=3a18 val=0
OV5640****: write reg=3a19 val=f8
ov5640_write_reg:write reg error:reg=3a19,val=f8
OV5640****: read reg=3a19 val=f8
OV5640****: write reg=3635 val=1c
ov5640_write_reg:write reg error:reg=3635,val=1c
OV5640****: read reg=3635 val=1c
OV5640****: write reg=3634 val=40
ov5640_write_reg:write reg error:reg=3634,val=40
OV5640****: read reg=3634 val=40
OV5640****: write reg=3622 val=1
ov5640_write_reg:write reg error:reg=3622,val=1
OV5640****: read reg=3622 val=1
OV5640****: write reg=3c01 val=34
ov5640_write_reg:write reg error:reg=3c01,val=34
OV5640****: read reg=3c01 val=34
OV5640****: write reg=3c04 val=28
ov5640_write_reg:write reg error:reg=3c04,val=28
OV5640****: read reg=3c04 val=28
OV5640****: write reg=3c05 val=98
ov5640_write_reg:write reg error:reg=3c05,val=98
OV5640****: read reg=3c05 val=98
OV5640****: write reg=3c06 val=0
ov5640_write_reg:write reg error:reg=3c06,val=0
OV5640****: read reg=3c06 val=0
OV5640****: write reg=3c07 val=8
ov5640_write_reg:write reg error:reg=3c07,val=8
OV5640****: read reg=3c07 val=8
OV5640****: write reg=3c08 val=0
ov5640_write_reg:write reg error:reg=3c08,val=0
OV5640****: read reg=3c08 val=0
OV5640****: write reg=3c09 val=1c
ov5640_write_reg:write reg error:reg=3c09,val=1c
OV5640****: read reg=3c09 val=1c
OV5640****: write reg=3c0a val=9c
ov5640_write_reg:write reg error:reg=3c0a,val=9c
OV5640****: read reg=3c0a val=9c
OV5640****: write reg=3c0b val=40
ov5640_write_reg:write reg error:reg=3c0b,val=40
OV5640****: read reg=3c0b val=40
OV5640****: write reg=3820 val=41
ov5640_write_reg:write reg error:reg=3820,val=41
OV5640****: read reg=3820 val=41
OV5640****: write reg=3821 val=7
ov5640_write_reg:write reg error:reg=3821,val=7
OV5640****: read reg=3821 val=7
OV5640****: write reg=3814 val=31
ov5640_write_reg:write reg error:reg=3814,val=31
OV5640****: read reg=3814 val=31
OV5640****: write reg=3815 val=31
ov5640_write_reg:write reg error:reg=3815,val=31
OV5640****: read reg=3815 val=31
OV5640****: write reg=3800 val=0
ov5640_write_reg:write reg error:reg=3800,val=0
OV5640****: read reg=3800 val=0
OV5640****: write reg=3801 val=0
ov5640_write_reg:write reg error:reg=3801,val=0
OV5640****: read reg=3801 val=0
OV5640****: write reg=3802 val=0
ov5640_write_reg:write reg error:reg=3802,val=0
OV5640****: read reg=3802 val=0
OV5640****: write reg=3803 val=4
ov5640_write_reg:write reg error:reg=3803,val=4
OV5640****: read reg=3803 val=4
OV5640****: write reg=3804 val=a
ov5640_write_reg:write reg error:reg=3804,val=a
OV5640****: read reg=3804 val=a
OV5640****: write reg=3805 val=3f
ov5640_write_reg:write reg error:reg=3805,val=3f
OV5640****: read reg=3805 val=3f
OV5640****: write reg=3806 val=7
ov5640_write_reg:write reg error:reg=3806,val=7
OV5640****: read reg=3806 val=7
OV5640****: write reg=3807 val=9f
ov5640_write_reg:write reg error:reg=3807,val=9f
OV5640****: read reg=3807 val=9f
OV5640****: write reg=3808 val=2
ov5640_write_reg:write reg error:reg=3808,val=2
OV5640****: read reg=3808 val=2
OV5640****: write reg=3809 val=80
ov5640_write_reg:write reg error:reg=3809,val=80
OV5640****: read reg=3809 val=80
OV5640****: write reg=380a val=1
ov5640_write_reg:write reg error:reg=380a,val=1
OV5640****: read reg=380a val=1
OV5640****: write reg=380b val=e0
ov5640_write_reg:write reg error:reg=380b,val=e0
OV5640****: read reg=380b val=e0
OV5640****: write reg=380c val=b
ov5640_write_reg:write reg error:reg=380c,val=b
OV5640****: read reg=380c val=b
OV5640****: write reg=380d val=1c
ov5640_write_reg:write reg error:reg=380d,val=1c
OV5640****: read reg=380d val=1c
OV5640****: write reg=380e val=7
ov5640_write_reg:write reg error:reg=380e,val=7
OV5640****: read reg=380e val=7
OV5640****: write reg=380f val=b0
ov5640_write_reg:write reg error:reg=380f,val=b0
OV5640****: read reg=380f val=b0
OV5640****: write reg=3810 val=0
ov5640_write_reg:write reg error:reg=3810,val=0
OV5640****: read reg=3810 val=0
OV5640****: write reg=3811 val=10
ov5640_write_reg:write reg error:reg=3811,val=10
OV5640****: read reg=3811 val=10
OV5640****: write reg=3812 val=0
ov5640_write_reg:write reg error:reg=3812,val=0
OV5640****: read reg=3812 val=0
OV5640****: write reg=3813 val=6
ov5640_write_reg:write reg error:reg=3813,val=6
OV5640****: read reg=3813 val=6
OV5640****: write reg=3814 val=11
ov5640_write_reg:write reg error:reg=3814,val=11
OV5640****: read reg=3814 val=11
OV5640****: write reg=3815 val=11
ov5640_write_reg:write reg error:reg=3815,val=11
OV5640****: read reg=3815 val=11
OV5640****: write reg=3618 val=0
ov5640_write_reg:write reg error:reg=3618,val=0
OV5640****: read reg=3618 val=0
OV5640****: write reg=3612 val=29
ov5640_write_reg:write reg error:reg=3612,val=29
OV5640****: read reg=3612 val=29
OV5640****: write reg=3708 val=62
ov5640_write_reg:write reg error:reg=3708,val=62
OV5640****: read reg=3708 val=62
OV5640****: write reg=3709 val=52
ov5640_write_reg:write reg error:reg=3709,val=52
OV5640****: read reg=3709 val=52
OV5640****: write reg=370c val=3
ov5640_write_reg:write reg error:reg=370c,val=3
OV5640****: read reg=370c val=3
OV5640****: write reg=3a02 val=3
ov5640_write_reg:write reg error:reg=3a02,val=3
OV5640****: read reg=3a02 val=3
OV5640****: write reg=3a03 val=d8
ov5640_write_reg:write reg error:reg=3a03,val=d8
OV5640****: read reg=3a03 val=d8
OV5640****: write reg=3a08 val=1
ov5640_write_reg:write reg error:reg=3a08,val=1
OV5640****: read reg=3a08 val=1
OV5640****: write reg=3a09 val=27
ov5640_write_reg:write reg error:reg=3a09,val=27
OV5640****: read reg=3a09 val=27
OV5640****: write reg=3a0a val=0
ov5640_write_reg:write reg error:reg=3a0a,val=0
OV5640****: read reg=3a0a val=0
OV5640****: write reg=3a0b val=f6
ov5640_write_reg:write reg error:reg=3a0b,val=f6
OV5640****: read reg=3a0b val=f6
OV5640****: write reg=3a0e val=3
ov5640_write_reg:write reg error:reg=3a0e,val=3
OV5640****: read reg=3a0e val=3
OV5640****: write reg=3a0d val=4
ov5640_write_reg:write reg error:reg=3a0d,val=4
OV5640****: read reg=3a0d val=4
OV5640****: write reg=3a14 val=3
ov5640_write_reg:write reg error:reg=3a14,val=3
OV5640****: read reg=3a14 val=3
OV5640****: write reg=3a15 val=d8
ov5640_write_reg:write reg error:reg=3a15,val=d8
OV5640****: read reg=3a15 val=d8
OV5640****: write reg=4000 val=1
ov5640_write_reg:write reg error:reg=4000,val=1
OV5640****: read reg=4000 val=1
OV5640****: write reg=4001 val=2
ov5640_write_reg:write reg error:reg=4001,val=2
OV5640****: read reg=4001 val=2
OV5640****: write reg=4004 val=2
ov5640_write_reg:write reg error:reg=4004,val=2
OV5640****: read reg=4004 val=2
OV5640****: write reg=3000 val=0
ov5640_write_reg:write reg error:reg=3000,val=0
OV5640****: read reg=3000 val=0
OV5640****: write reg=3002 val=1c
ov5640_write_reg:write reg error:reg=3002,val=1c
OV5640****: read reg=3002 val=1c
OV5640****: write reg=3004 val=ff
ov5640_write_reg:write reg error:reg=3004,val=ff
OV5640****: read reg=3004 val=ff
OV5640****: write reg=3006 val=c3
ov5640_write_reg:write reg error:reg=3006,val=c3
OV5640****: read reg=3006 val=c3
OV5640****: write reg=300e val=58
ov5640_write_reg:write reg error:reg=300e,val=58
OV5640****: read reg=300e val=58
OV5640****: write reg=302e val=0
ov5640_write_reg:write reg error:reg=302e,val=0
OV5640****: read reg=302e val=0
OV5640****: write reg=4300 val=30
ov5640_write_reg:write reg error:reg=4300,val=30
OV5640****: read reg=4300 val=30
OV5640****: write reg=501f val=0
ov5640_write_reg:write reg error:reg=501f,val=0
OV5640****: read reg=501f val=0
OV5640****: write reg=5027 val=1
ov5640_write_reg:write reg error:reg=5027,val=1
OV5640****: read reg=5027 val=1
OV5640****: write reg=5028 val=4
ov5640_write_reg:write reg error:reg=5028,val=4
OV5640****: read reg=5028 val=4
OV5640****: write reg=5029 val=90
ov5640_write_reg:write reg error:reg=5029,val=90
OV5640****: read reg=5029 val=90
OV5640****: write reg=502a val=5
ov5640_write_reg:write reg error:reg=502a,val=5
OV5640****: read reg=502a val=5
OV5640****: write reg=502b val=90
ov5640_write_reg:write reg error:reg=502b,val=90
OV5640****: read reg=502b val=90
OV5640****: write reg=502c val=3
ov5640_write_reg:write reg error:reg=502c,val=3
OV5640****: read reg=502c val=3
OV5640****: write reg=4713 val=3
ov5640_write_reg:write reg error:reg=4713,val=3
OV5640****: read reg=4713 val=3
OV5640****: write reg=4407 val=4
ov5640_write_reg:write reg error:reg=4407,val=4
OV5640****: read reg=4407 val=4
OV5640****: write reg=502d val=6c
ov5640_write_reg:write reg error:reg=502d,val=6c
OV5640****: read reg=502d val=6c
OV5640****: write reg=502e val=4
ov5640_write_reg:write reg error:reg=502e,val=4
OV5640****: read reg=502e val=4
OV5640****: write reg=502f val=2c
ov5640_write_reg:write reg error:reg=502f,val=2c
OV5640****: read reg=502f val=2c
OV5640****: write reg=5034 val=80
ov5640_write_reg:write reg error:reg=5034,val=80
OV5640****: read reg=5034 val=80
OV5640****: write reg=5035 val=2a
ov5640_write_reg:write reg error:reg=5035,val=2a
OV5640****: read reg=5035 val=2a
OV5640****: write reg=5036 val=14
ov5640_write_reg:write reg error:reg=5036,val=14
OV5640****: read reg=5036 val=14
OV5640****: write reg=460b val=35
ov5640_write_reg:write reg error:reg=460b,val=35
OV5640****: read reg=460b val=35
OV5640****: write reg=460c val=22
ov5640_write_reg:write reg error:reg=460c,val=22
OV5640****: read reg=460c val=22
OV5640****: write reg=3824 val=2
ov5640_write_reg:write reg error:reg=3824,val=2
OV5640****: read reg=3824 val=2
OV5640****: write reg=5000 val=a7
ov5640_write_reg:write reg error:reg=5000,val=a7
OV5640****: read reg=5000 val=a7
OV5640****: write reg=5001 val=23
ov5640_write_reg:write reg error:reg=5001,val=23
OV5640****: read reg=5001 val=23
OV5640****: write reg=5005 val=36
ov5640_write_reg:write reg error:reg=5005,val=36
OV5640****: read reg=5005 val=36
OV5640****: write reg=5180 val=ff
ov5640_write_reg:write reg error:reg=5180,val=ff
OV5640****: read reg=5180 val=ff
OV5640****: write reg=5181 val=f2
ov5640_write_reg:write reg error:reg=5181,val=f2
OV5640****: read reg=5181 val=f2
OV5640****: write reg=5182 val=0
ov5640_write_reg:write reg error:reg=5182,val=0
OV5640****: read reg=5182 val=0
OV5640****: write reg=5183 val=90
ov5640_write_reg:write reg error:reg=5183,val=90
OV5640****: read reg=5183 val=90
OV5640****: write reg=5184 val=25
ov5640_write_reg:write reg error:reg=5184,val=25
OV5640****: read reg=5184 val=25
OV5640****: write reg=5185 val=24
ov5640_write_reg:write reg error:reg=5185,val=24
OV5640****: read reg=5185 val=24
OV5640****: write reg=5186 val=9
ov5640_write_reg:write reg error:reg=5186,val=9
OV5640****: read reg=5186 val=9
OV5640****: write reg=5187 val=9
ov5640_write_reg:write reg error:reg=5187,val=9
OV5640****: read reg=5187 val=9
OV5640****: write reg=5188 val=9
ov5640_write_reg:write reg error:reg=5188,val=9
OV5640****: read reg=5188 val=9
OV5640****: write reg=5189 val=75
ov5640_write_reg:write reg error:reg=5189,val=75
OV5640****: read reg=5189 val=75
OV5640****: write reg=518a val=54
ov5640_write_reg:write reg error:reg=518a,val=54
OV5640****: read reg=518a val=54
OV5640****: write reg=518b val=e0
ov5640_write_reg:write reg error:reg=518b,val=e0
OV5640****: read reg=518b val=e0
OV5640****: write reg=518c val=b2
ov5640_write_reg:write reg error:reg=518c,val=b2
OV5640****: read reg=518c val=b2
OV5640****: write reg=518d val=42
ov5640_write_reg:write reg error:reg=518d,val=42
OV5640****: read reg=518d val=42
OV5640****: write reg=518e val=3d
ov5640_write_reg:write reg error:reg=518e,val=3d
OV5640****: read reg=518e val=3d
OV5640****: write reg=518f val=56
ov5640_write_reg:write reg error:reg=518f,val=56
OV5640****: read reg=518f val=56
OV5640****: write reg=5190 val=46
ov5640_write_reg:write reg error:reg=5190,val=46
OV5640****: read reg=5190 val=46
OV5640****: write reg=5191 val=f8
ov5640_write_reg:write reg error:reg=5191,val=f8
OV5640****: read reg=5191 val=f8
OV5640****: write reg=5192 val=4
ov5640_write_reg:write reg error:reg=5192,val=4
OV5640****: read reg=5192 val=4
OV5640****: write reg=5381 val=1c
ov5640_write_reg:write reg error:reg=5381,val=1c
OV5640****: read reg=5381 val=1c
OV5640****: write reg=5382 val=5a
ov5640_write_reg:write reg error:reg=5382,val=5a
OV5640****: read reg=5382 val=5a
OV5640****: write reg=5383 val=6
ov5640_write_reg:write reg error:reg=5383,val=6
OV5640****: read reg=5383 val=6
OV5640****: write reg=5384 val=a
ov5640_write_reg:write reg error:reg=5384,val=a
OV5640****: read reg=5384 val=a
OV5640****: write reg=5385 val=7e
ov5640_write_reg:write reg error:reg=5385,val=7e
OV5640****: read reg=5385 val=7e
OV5640****: write reg=5386 val=88
ov5640_write_reg:write reg error:reg=5386,val=88
OV5640****: read reg=5386 val=88
OV5640****: write reg=5387 val=7c
ov5640_write_reg:write reg error:reg=5387,val=7c
OV5640****: read reg=5387 val=7c
OV5640****: write reg=5388 val=6c
ov5640_write_reg:write reg error:reg=5388,val=6c
OV5640****: read reg=5388 val=6c
OV5640****: write reg=5389 val=10
ov5640_write_reg:write reg error:reg=5389,val=10
OV5640****: read reg=5389 val=10
OV5640****: write reg=538a val=1
ov5640_write_reg:write reg error:reg=538a,val=1
OV5640****: read reg=538a val=1
OV5640****: write reg=538b val=98
ov5640_write_reg:write reg error:reg=538b,val=98
OV5640****: read reg=538b val=98
OV5640****: write reg=5300 val=8
ov5640_write_reg:write reg error:reg=5300,val=8
OV5640****: read reg=5300 val=8
OV5640****: write reg=5301 val=30
ov5640_write_reg:write reg error:reg=5301,val=30
OV5640****: read reg=5301 val=30
OV5640****: write reg=5302 val=10
ov5640_write_reg:write reg error:reg=5302,val=10
OV5640****: read reg=5302 val=10
OV5640****: write reg=5303 val=0
ov5640_write_reg:write reg error:reg=5303,val=0
OV5640****: read reg=5303 val=0
OV5640****: write reg=5304 val=8
ov5640_write_reg:write reg error:reg=5304,val=8
OV5640****: read reg=5304 val=8
OV5640****: write reg=5305 val=30
ov5640_write_reg:write reg error:reg=5305,val=30
OV5640****: read reg=5305 val=30
OV5640****: write reg=5306 val=8
ov5640_write_reg:write reg error:reg=5306,val=8
OV5640****: read reg=5306 val=8
OV5640****: write reg=5307 val=16
ov5640_write_reg:write reg error:reg=5307,val=16
OV5640****: read reg=5307 val=16
OV5640****: write reg=5309 val=8
ov5640_write_reg:write reg error:reg=5309,val=8
OV5640****: read reg=5309 val=8
OV5640****: write reg=530a val=30
ov5640_write_reg:write reg error:reg=530a,val=30
OV5640****: read reg=530a val=30
OV5640****: write reg=530b val=4
ov5640_write_reg:write reg error:reg=530b,val=4
OV5640****: read reg=530b val=4
OV5640****: write reg=530c val=6
ov5640_write_reg:write reg error:reg=530c,val=6
OV5640****: read reg=530c val=6
OV5640****: write reg=5480 val=1
ov5640_write_reg:write reg error:reg=5480,val=1
OV5640****: read reg=5480 val=1
OV5640****: write reg=5481 val=8
ov5640_write_reg:write reg error:reg=5481,val=8
OV5640****: read reg=5481 val=8
OV5640****: write reg=5482 val=14
ov5640_write_reg:write reg error:reg=5482,val=14
OV5640****: read reg=5482 val=14
OV5640****: write reg=5483 val=28
ov5640_write_reg:write reg error:reg=5483,val=28
OV5640****: read reg=5483 val=28
OV5640****: write reg=5484 val=51
ov5640_write_reg:write reg error:reg=5484,val=51
OV5640****: read reg=5484 val=51
OV5640****: write reg=5485 val=65
ov5640_write_reg:write reg error:reg=5485,val=65
OV5640****: read reg=5485 val=65
OV5640****: write reg=5486 val=71
ov5640_write_reg:write reg error:reg=5486,val=71
OV5640****: read reg=5486 val=71
OV5640****: write reg=5487 val=7d
ov5640_write_reg:write reg error:reg=5487,val=7d
OV5640****: read reg=5487 val=7d
OV5640****: write reg=5488 val=87
ov5640_write_reg:write reg error:reg=5488,val=87
OV5640****: read reg=5488 val=87
OV5640****: write reg=5489 val=91
ov5640_write_reg:write reg error:reg=5489,val=91
OV5640****: read reg=5489 val=91
OV5640****: write reg=548a val=9a
ov5640_write_reg:write reg error:reg=548a,val=9a
OV5640****: read reg=548a val=9a
OV5640****: write reg=548b val=aa
ov5640_write_reg:write reg error:reg=548b,val=aa
OV5640****: read reg=548b val=aa
OV5640****: write reg=548c val=b8
ov5640_write_reg:write reg error:reg=548c,val=b8
OV5640****: read reg=548c val=b8
OV5640****: write reg=548d val=cd
ov5640_write_reg:write reg error:reg=548d,val=cd
OV5640****: read reg=548d val=cd
OV5640****: write reg=548e val=dd
ov5640_write_reg:write reg error:reg=548e,val=dd
OV5640****: read reg=548e val=dd
OV5640****: write reg=548f val=ea
ov5640_write_reg:write reg error:reg=548f,val=ea
OV5640****: read reg=548f val=ea
OV5640****: write reg=5490 val=1d
ov5640_write_reg:write reg error:reg=5490,val=1d
OV5640****: read reg=5490 val=1d
OV5640****: write reg=5580 val=2
ov5640_write_reg:write reg error:reg=5580,val=2
OV5640****: read reg=5580 val=2
OV5640****: write reg=5583 val=40
ov5640_write_reg:write reg error:reg=5583,val=40
OV5640****: read reg=5583 val=40
OV5640****: write reg=5584 val=10
ov5640_write_reg:write reg error:reg=5584,val=10
OV5640****: read reg=5584 val=10
OV5640****: write reg=5589 val=10
ov5640_write_reg:write reg error:reg=5589,val=10
OV5640****: read reg=5589 val=10
OV5640****: write reg=558a val=0
ov5640_write_reg:write reg error:reg=558a,val=0
OV5640****: read reg=558a val=0
OV5640****: write reg=558b val=f8
ov5640_write_reg:write reg error:reg=558b,val=f8
OV5640****: read reg=558b val=f8
OV5640****: write reg=5800 val=23
ov5640_write_reg:write reg error:reg=5800,val=23
OV5640****: read reg=5800 val=23
OV5640****: write reg=5801 val=15
ov5640_write_reg:write reg error:reg=5801,val=15
OV5640****: read reg=5801 val=15
OV5640****: write reg=5802 val=10
ov5640_write_reg:write reg error:reg=5802,val=10
OV5640****: read reg=5802 val=10
OV5640****: write reg=5803 val=10
ov5640_write_reg:write reg error:reg=5803,val=10
OV5640****: read reg=5803 val=10
OV5640****: write reg=5804 val=15
ov5640_write_reg:write reg error:reg=5804,val=15
OV5640****: read reg=5804 val=15
OV5640****: write reg=5805 val=23
ov5640_write_reg:write reg error:reg=5805,val=23
OV5640****: read reg=5805 val=23
OV5640****: write reg=5806 val=c
ov5640_write_reg:write reg error:reg=5806,val=c
OV5640****: read reg=5806 val=c
OV5640****: write reg=5807 val=8
ov5640_write_reg:write reg error:reg=5807,val=8
OV5640****: read reg=5807 val=8
OV5640****: write reg=5808 val=5
ov5640_write_reg:write reg error:reg=5808,val=5
OV5640****: read reg=5808 val=5
OV5640****: write reg=5809 val=5
ov5640_write_reg:write reg error:reg=5809,val=5
OV5640****: read reg=5809 val=5
OV5640****: write reg=580a val=8
ov5640_write_reg:write reg error:reg=580a,val=8
OV5640****: read reg=580a val=8
OV5640****: write reg=580b val=c
ov5640_write_reg:write reg error:reg=580b,val=c
OV5640****: read reg=580b val=c
OV5640****: write reg=580c val=7
ov5640_write_reg:write reg error:reg=580c,val=7
OV5640****: read reg=580c val=7
OV5640****: write reg=580d val=3
ov5640_write_reg:write reg error:reg=580d,val=3
OV5640****: read reg=580d val=3
OV5640****: write reg=580e val=0
ov5640_write_reg:write reg error:reg=580e,val=0
OV5640****: read reg=580e val=0
OV5640****: write reg=580f val=0
ov5640_write_reg:write reg error:reg=580f,val=0
OV5640****: read reg=580f val=0
OV5640****: write reg=5810 val=3
ov5640_write_reg:write reg error:reg=5810,val=3
OV5640****: read reg=5810 val=3
OV5640****: write reg=5811 val=7
ov5640_write_reg:write reg error:reg=5811,val=7
OV5640****: read reg=5811 val=7
OV5640****: write reg=5812 val=7
ov5640_write_reg:write reg error:reg=5812,val=7
OV5640****: read reg=5812 val=7
OV5640****: write reg=5813 val=3
ov5640_write_reg:write reg error:reg=5813,val=3
OV5640****: read reg=5813 val=3
OV5640****: write reg=5814 val=0
ov5640_write_reg:write reg error:reg=5814,val=0
OV5640****: read reg=5814 val=0
OV5640****: write reg=5815 val=0
ov5640_write_reg:write reg error:reg=5815,val=0
OV5640****: read reg=5815 val=0
OV5640****: write reg=5816 val=3
ov5640_write_reg:write reg error:reg=5816,val=3
OV5640****: read reg=5816 val=3
OV5640****: write reg=5817 val=7
ov5640_write_reg:write reg error:reg=5817,val=7
OV5640****: read reg=5817 val=7
OV5640****: write reg=5818 val=b
ov5640_write_reg:write reg error:reg=5818,val=b
OV5640****: read reg=5818 val=b
OV5640****: write reg=5819 val=8
ov5640_write_reg:write reg error:reg=5819,val=8
OV5640****: read reg=5819 val=8
OV5640****: write reg=581a val=5
ov5640_write_reg:write reg error:reg=581a,val=5
OV5640****: read reg=581a val=5
OV5640****: write reg=581b val=5
ov5640_write_reg:write reg error:reg=581b,val=5
OV5640****: read reg=581b val=5
OV5640****: write reg=581c val=7
ov5640_write_reg:write reg error:reg=581c,val=7
OV5640****: read reg=581c val=7
OV5640****: write reg=581d val=b
ov5640_write_reg:write reg error:reg=581d,val=b
OV5640****: read reg=581d val=b
OV5640****: write reg=581e val=2a
ov5640_write_reg:write reg error:reg=581e,val=2a
OV5640****: read reg=581e val=2a
OV5640****: write reg=581f val=16
ov5640_write_reg:write reg error:reg=581f,val=16
OV5640****: read reg=581f val=16
OV5640****: write reg=5820 val=11
ov5640_write_reg:write reg error:reg=5820,val=11
OV5640****: read reg=5820 val=11
OV5640****: write reg=5821 val=11
ov5640_write_reg:write reg error:reg=5821,val=11
OV5640****: read reg=5821 val=11
OV5640****: write reg=5822 val=15
ov5640_write_reg:write reg error:reg=5822,val=15
OV5640****: read reg=5822 val=15
OV5640****: write reg=5823 val=29
ov5640_write_reg:write reg error:reg=5823,val=29
OV5640****: read reg=5823 val=29
OV5640****: write reg=5824 val=bf
ov5640_write_reg:write reg error:reg=5824,val=bf
OV5640****: read reg=5824 val=bf
OV5640****: write reg=5825 val=af
ov5640_write_reg:write reg error:reg=5825,val=af
OV5640****: read reg=5825 val=af
OV5640****: write reg=5826 val=9f
ov5640_write_reg:write reg error:reg=5826,val=9f
OV5640****: read reg=5826 val=9f
OV5640****: write reg=5827 val=af
ov5640_write_reg:write reg error:reg=5827,val=af
OV5640****: read reg=5827 val=af
OV5640****: write reg=5828 val=df
ov5640_write_reg:write reg error:reg=5828,val=df
OV5640****: read reg=5828 val=df
OV5640****: write reg=5829 val=6f
ov5640_write_reg:write reg error:reg=5829,val=6f
OV5640****: read reg=5829 val=6f
OV5640****: write reg=582a val=8e
ov5640_write_reg:write reg error:reg=582a,val=8e
OV5640****: read reg=582a val=8e
OV5640****: write reg=582b val=ab
ov5640_write_reg:write reg error:reg=582b,val=ab
OV5640****: read reg=582b val=ab
OV5640****: write reg=582c val=9e
ov5640_write_reg:write reg error:reg=582c,val=9e
OV5640****: read reg=582c val=9e
OV5640****: write reg=582d val=7f
ov5640_write_reg:write reg error:reg=582d,val=7f
OV5640****: read reg=582d val=7f
OV5640****: write reg=582e val=4f
ov5640_write_reg:write reg error:reg=582e,val=4f
OV5640****: read reg=582e val=4f
OV5640****: write reg=582f val=89
ov5640_write_reg:write reg error:reg=582f,val=89
OV5640****: read reg=582f val=89
OV5640****: write reg=5830 val=86
ov5640_write_reg:write reg error:reg=5830,val=86
OV5640****: read reg=5830 val=86
OV5640****: write reg=5831 val=98
ov5640_write_reg:write reg error:reg=5831,val=98
OV5640****: read reg=5831 val=98
OV5640****: write reg=5832 val=6f
ov5640_write_reg:write reg error:reg=5832,val=6f
OV5640****: read reg=5832 val=6f
OV5640****: write reg=5833 val=4f
ov5640_write_reg:write reg error:reg=5833,val=4f
OV5640****: read reg=5833 val=4f
OV5640****: write reg=5834 val=6e
ov5640_write_reg:write reg error:reg=5834,val=6e
OV5640****: read reg=5834 val=6e
OV5640****: write reg=5835 val=7b
ov5640_write_reg:write reg error:reg=5835,val=7b
OV5640****: read reg=5835 val=7b
OV5640****: write reg=5836 val=7e
ov5640_write_reg:write reg error:reg=5836,val=7e
OV5640****: read reg=5836 val=7e
OV5640****: write reg=5837 val=6f
ov5640_write_reg:write reg error:reg=5837,val=6f
OV5640****: read reg=5837 val=6f
OV5640****: write reg=5838 val=de
ov5640_write_reg:write reg error:reg=5838,val=de
OV5640****: read reg=5838 val=de
OV5640****: write reg=5839 val=bf
ov5640_write_reg:write reg error:reg=5839,val=bf
OV5640****: read reg=5839 val=bf
OV5640****: write reg=583a val=9f
ov5640_write_reg:write reg error:reg=583a,val=9f
OV5640****: read reg=583a val=9f
OV5640****: write reg=583b val=bf
ov5640_write_reg:write reg error:reg=583b,val=bf
OV5640****: read reg=583b val=bf
OV5640****: write reg=583c val=ec
ov5640_write_reg:write reg error:reg=583c,val=ec
OV5640****: read reg=583c val=ec
OV5640****: write reg=5025 val=0
ov5640_write_reg:write reg error:reg=5025,val=0
OV5640****: read reg=5025 val=0
OV5640****: write reg=3a0f val=30
ov5640_write_reg:write reg error:reg=3a0f,val=30
OV5640****: read reg=3a0f val=30
OV5640****: write reg=3a10 val=28
ov5640_write_reg:write reg error:reg=3a10,val=28
OV5640****: read reg=3a10 val=28
OV5640****: write reg=3a1b val=30
ov5640_write_reg:write reg error:reg=3a1b,val=30
OV5640****: read reg=3a1b val=30
OV5640****: write reg=3a1e val=26
ov5640_write_reg:write reg error:reg=3a1e,val=26
OV5640****: read reg=3a1e val=26
OV5640****: write reg=3a11 val=60
ov5640_write_reg:write reg error:reg=3a11,val=60
OV5640****: read reg=3a11 val=60
OV5640****: write reg=3a1f val=14
ov5640_write_reg:write reg error:reg=3a1f,val=14
OV5640****: read reg=3a1f val=14
OV5640****: write reg=3008 val=2
ov5640_write_reg:write reg error:reg=3008,val=2
OV5640****: write reg=3035 val=21
ov5640_write_reg:write reg error:reg=3035,val=21
OV5640****: read reg=3035 val=21
OV5640****: write reg=4741 val=1
ov5640_write_reg:write reg error:reg=4741,val=1
OV5640****: read reg=4741 val=1
OV5640****: read reg=3001 val=8
OV5640****: read reg=3003 val=0
OV5640****: read reg=3005 val=f7
OV5640****: read reg=3007 val=ff
OV5640****: read reg=3009 val=1
OV5640****: read reg=300a val=56
OV5640****: read reg=300b val=40
OV5640****: read reg=300c val=22
OV5640****: read reg=300d val=0
OV5640****: read reg=300f val=0
OV5640****: read reg=3010 val=0
OV5640****: read reg=3011 val=0
OV5640****: read reg=3012 val=0
OV5640****: read reg=3013 val=0
OV5640****: read reg=3014 val=0
OV5640****: read reg=3015 val=7
OV5640****: read reg=3016 val=0
OV5640****: read reg=3019 val=f0
OV5640****: read reg=301a val=0
OV5640****: read reg=301b val=0
OV5640****: read reg=301c val=0
OV5640****: read reg=301d val=0
OV5640****: read reg=301e val=0
OV5640****: read reg=301f val=0
OV5640****: read reg=3020 val=0
OV5640****: read reg=3021 val=0
OV5640****: read reg=3022 val=0
OV5640****: read reg=3023 val=0
OV5640****: read reg=3024 val=0
OV5640****: read reg=3025 val=0
OV5640****: read reg=3026 val=0
OV5640****: read reg=3027 val=0
OV5640****: read reg=3028 val=0
OV5640****: read reg=3029 val=0
OV5640****: read reg=302a val=b0
OV5640****: read reg=302b val=0
OV5640****: read reg=302c val=2
OV5640****: read reg=302f val=2
OV5640****: read reg=3030 val=b
OV5640****: read reg=3031 val=0
OV5640****: read reg=3032 val=0
OV5640****: read reg=3033 val=3
OV5640****: read reg=3038 val=0
OV5640****: read reg=3039 val=0
OV5640****: read reg=303a val=0
OV5640****: read reg=303b val=19
OV5640****: read reg=303c val=11
OV5640****: read reg=303e val=0
OV5640****: read reg=303f val=0
OV5640****: read reg=3040 val=10
OV5640****: read reg=3041 val=ff
OV5640****: read reg=3042 val=0
OV5640****: read reg=3043 val=ff
OV5640****: read reg=3044 val=9
OV5640****: read reg=3045 val=0
OV5640****: read reg=3046 val=0
OV5640****: read reg=3047 val=0
OV5640****: read reg=3048 val=0
OV5640****: read reg=3049 val=0
OV5640****: read reg=304a val=0
OV5640****: read reg=304b val=0
OV5640****: read reg=304c val=0
OV5640****: read reg=304d val=0
OV5640****: read reg=304e val=0
OV5640****: read reg=304f val=0
OV5640****: read reg=3050 val=7
OV5640****: read reg=3051 val=2
OV5640****: read reg=3052 val=b0
mxc_v4l2_output mxc_v4l2_output.0: Registered device video1
usbcore: registered new interface driver uvcvideo
USB Video Class driver (v0.1.0)
APM Battery Driver
oviya check mma8450 chip ID
ovi MMA8450 ACCELEROMETER and RESUL:0xf 0xc6
mma8450 0-001c: build time Sep 6 2012 13:18:44
input: mma8450 as /devices/virtual/input/input3
add mma8450 i2c driver
OVIYA MMA8452 INIT OK 0x0
MXC WatchDog Driver 2.0
MXC Watchdog # 0 Timer: initial timeout 60 sec
Bluetooth: Virtual HCI driver ver 1.3
Bluetooth: HCI UART driver ver 2.2
Bluetooth: HCIATH3K protocol initialized
Bluetooth: Generic Bluetooth USB driver ver 0.6
usbcore: registered new interface driver btusb
VPU initialized
mxc_asrc registered
gpu mmu disabled
mxsdhci: MXC Secure Digital Host Controller Interface driver
mxsdhci: MXC SDHCI Controller Driver.
mmc0: SDHCI detect irq 0 irq 1 INTERNAL DMA
mmc1: SDHCI detect irq 203 irq 3 INTERNAL DMA
usbhid: USB HID core driver
Cirrus Logic CS42888 ALSA SoC Codec Driver
mxc_spdif mxc_spdif.0: MXC SPDIF Audio Transmitter
No device for codec mxc spdif
No device for DAI mxc spdif
No device for DAI imx-ssi-1-0
No device for DAI imx-ssi-1-1
No device for DAI imx-ssi-2-0
No device for DAI imx-ssi-2-1
No device for DAI imx-spdif-dai
DMA Sound Buffer Allocated: Playback UseIram=1 ext_ram=1 buf->addr=73fc8000 buf-
>area=fabfa000 size=24576
asoc: mxc spdif <-> imx-spdif-dai mapping ok
ALSA device list:
#0: imx-3stack-spdif (mxc spdif)
TCP cubic registered
can: controller area network core (rev 20090105 abi 8)
NET: Registered protocol family 29
can: raw protocol (rev 20090105)
can: broadcast manager protocol (rev 20090105 t)
Bluetooth: L2CAP ver 2.14
Bluetooth: L2CAP socket layer initialized
Bluetooth: SCO (Voice Link) ver 0.6
Bluetooth: SCO socket layer initialized
Bluetooth: RFCOMM TTY layer initialized
Bluetooth: RFCOMM socket layer initialized
Bluetooth: RFCOMM ver 1.11
Bluetooth: BNEP (Ethernet Emulation) ver 1.3
Bluetooth: BNEP filters: protocol multicast
Bluetooth: HIDP (Human Interface Emulation) ver 1.2
VFP support v0.3: implementor 41 architecture 3 part 30 variant c rev 2
regulator_init_complete: incomplete constraints, leaving DA9052_BUCK_PERI on
regulator_init_complete: incomplete constraints, leaving DA9052_BUCK_MEM on
regulator_init_complete: incomplete constraints, leaving DA9052_BUCK_PRO on
regulator_init_complete: incomplete constraints, leaving DA9052_BUCK_CORE on
regulator_init_complete: incomplete constraints, leaving DA9052_LDO10 on
regulator_init_complete: incomplete constraints, leaving DA9052_LDO9 on
regulator_init_complete: incomplete constraints, leaving DA9052_LDO8 on
regulator_init_complete: incomplete constraints, leaving DA9052_LDO6 on
regulator_init_complete: incomplete constraints, leaving DA9052_LDO5 on
regulator_init_complete: incomplete constraints, leaving DA9052_LDO3 on
regulator_init_complete: incomplete constraints, leaving DA9052_LDO2 on
regulator_init_complete: incomplete constraints, leaving DA9052_LDO1 on
mxc_rtc mxc_rtc.0: setting system clock to 1970-01-01 00:00:04 UTC (4)
mmc0: new SDHC card at address e624
mmcblk0: mmc0:e624 SU16G 14.8 GiB
mmcblk0: p1
eth0: Freescale FEC PHY driver [Generic PHY] (mii_bus:phy_addr=0:00, irq=-1)
IP-Config: Complete:
device=eth0, addr=192.168.0.150, mask=255.255.255.0, gw=192.168.0.1,
host=192.168.0.150, domain=, nis-domain=(none),
bootserver=192.168.0.50, rootserver=192.168.0.50, rootpath=
Looking up port of RPC 100003/2 on 192.168.0.50
PHY: 0:00 - Link is Up - 100/Full
Looking up port of RPC 100005/1 on 192.168.0.50
VFS: Mounted root (nfs filesystem) on device 0:11.
Freeing init memory: 172K
starting pid 1188, tty '': '/etc/rc.d/rcS'
Mounting /proc and /sys
Starting the hotplug events dispatcher udevd
Synthesizing initial hotplug events
Setting the hostname to freescale
Mounting filesystems
mount: mounting usbfs on /proc/bus/usb failed: No such file or directory
Starting the dropbear ssh server:
D-Bus per-session daemon address is: unix:abstract=/tmp/dbus-SpDiTEOhS4,guid=a5f
bbe5a49ef8f40e8b435840000000c
gtk: creating gdk-pixbuf.loaders
pango: creating module list
chown: /home/user/.rhosts: Operation not permitted
chown: /home/user: Operation not permitted
starting pid 2229, tty '': '/sbin/getty -L ttymxc0 115200 vt100'
_XSERVTransSocketOpenCOTSServer: Unable to open socket for inet6
_XSERVTransOpen: transport open failed for inet6/freescale:0
_XSERVTransMakeAllCOTSServerListeners: failed to open listener for inet6
_XSERVTransmkdir: Owner of /tmp/.X11-unix should be set to root
(EE) XKB: Couldn't open rules file /usr/share/X11/xkb/rules/base
(EE) XKB: No components provided for device Virtual core keyboard
unrecognised device identifier!
(EE) config/hal: NewInputDeviceRequest failed (2)
arm-none-linux-gnueabi-gcc (4.4.4_09.06.2010) 4.4.4
root filesystem built on Thu, 29 Sep 2011 15:54:39 +0800
Freescale Semiconductor, Inc.
freescale login: root
login[2229]: root login on 'ttymxc0'
BusyBox v1.18.5 () built-in shell (ash)
Enter 'help' for a list of built-in commands.
root@freescale ~$ matchbox: keyboard does not appear to have a <alt> key.
matchbox: ignoring key shortcut <Alt>n=next
matchbox: ignoring key shortcut <Alt>p=prev
matchbox: ignoring key shortcut <Alt>c=close
matchbox: ignoring key shortcut <Alt>d=desktop
matchbox: ignoring key shortcut <Alt>m=!matchbox-remote -mbmenu
matchbox: ignoring key shortcut <ctrl><alt>x=!xterm
matchbox: ignoring key shortcut <ctrl><alt>r=!rxvt
matchbox: ignoring key shortcut <ctrl><alt>e=!!gpe-calender
matchbox: ignoring key shortcut <alt>Tab=next
matchbox: ignoring key shortcut <alt><shift>Tab=prev
matchbox: ignoring key shortcut <alt>space=taskmenu
matchbox: ignoring key shortcut <alt>escape=!matchbox-remote -mbmenu
matchbox: ignoring key shortcut <alt>f4=close
matchbox: Cant find a keycode for keysym 65480
matchbox: ignoring key shortcut f11=fullscreen
matchbox-desktop: loading /usr/lib/matchbox/desktop/tasks.so with args ( None )
matchbox-desktop: loading /usr/lib/matchbox/desktop/dotdesktop.so with args ( No
ne )
user_overides is (nil)
mb-applet-menu-launcher: bonobo-browser.desktop has no icon, png or name
mb-desktop-dotdesktop: failed to open /usr/local/share/applications
mb-desktop-dotdesktop: failed to open //.applications
mb-applet-menu-launcher: failed to open /usr/local/share/applications
mb-applet-menu-launcher: failed to open //.applications
root@freescale ~$ root
-sh: root: not found
root@freescale ~$ ls
root@freescale ~$ cd /
root@freescale /$ ls
The_Adventures_of_Tintin.mp4 proc
bin root
dev sbin
etc sys
home test_image150.avi
lib tmp
lost+found unit_tests
mnt usr
opt var
root@freescale /$ gplroot@freescale /$ gplay Troot@freescale /$ gplay The_Adventures_of_Tintin.mp4
playbin2 is employed!
fsl_player_init(): Successfully initialize!
fsl_player_set_media_location(): filename=The_Adventures_of_Tintin.mp4
[Stopped ][Vol=01][00:00:00/00:00:00][fps:0]Aiur: 2.0.3
Core: MPEG4PARSER_06.04.04 build on Sep 27 2011 09:56:41
mime: video/quicktime; audio/x-m4a; application/x-3gp
file: lib_mp4_parser_arm11_elinux.3.0.so.6.4.3
Content Info:
URI:
file:////The_Adventures_of_Tintin.mp4
Idx File:
/root/.aiur/..The_Adventures_of_Tintin.mp4.aidx
Seekable : Yes
Size(byte): 15878110
Movie Info:
Seekable : Yes
Live : No
Duration : 0:01:12.084000000
ReadMode : File
Track : 2
Track 00[Video]: Enabled
Duration: 0:01:12.083000000
Language: und
Mime:
video/mpeg, mpegversion=(int)4, parsed=(boolean)true, width=(int)8
00, height=(in
t)480, framerate=(fraction)24/1
[INFO] Product Info: i.MX53
VPU Version: firmware 13.4.41; libvpu: 5.3.2
MFW_GST_VPU_DECODER_PLUGIN 2.0.3 build on Sep 29 2011 15:40:37.
Track 01[Audio]: Enabled
Duration: 0:01:11.935000000
Language: und
Mime:
audio/mpeg, mpegversion=(int)4, channels=(int)2, rate=(int)44100,
bitrate=(int)0
Unhandled fault: external abort on non-linefetch (0x1018) at 0x2ebf105
4
, framed=(boolean)true
BLN_MAD-MMCODECS_AACD_ARM_03.06.00 build on May 9 2011 17:11:11.
MFW_GST_AAC_PLUGIN 2.0.3 build on Sep 29 2011 15:41:01.
FOUND GST_MESSAGE_TAG!
codec: MPEG4
language code: und
container format: MOV/MP4/3GP
codec: AAC
language code: und
MFW_GST_V4LSINK_PLUGIN 2.0.3 build on Sep 29 2011 15:40:57.
spdif_set_sample_rate: no defined 44100 clk src
mxc_spdif_playback_prepare - err < 0
asoc: codec DAI prepare error
audio codec: AAC decoder
bitrate: 0
sampling frequency (Hz): 44100
number of channels: 2
gplay: page allocation failure. order:8, mode:0xd1
[<80038430>] (unwind_backtrace+0x0/0xec) from [<8009b438>] (__alloc_pages_nodema
sk+0x508/0x55c)
[<8009b438>] (__alloc_pages_nodemask+0x508/0x55c) from [<80038dd0>] (__dma_alloc
+0xf0/0x2a8)
[<80038dd0>] (__dma_alloc+0xf0/0x2a8) from [<80039008>] (dma_alloc_coherent+0x54
/0x60)
[<80039008>] (dma_alloc_coherent+0x54/0x60) from [<80301060>] (mxc_allocate_buff
ers+0x28/0x84)
[<80301060>] (mxc_allocate_buffers+0x28/0x84) from [<803045f8>] (mxc_v4l2out_do_
ioctl+0x4bc/0xea0)
[<803045f8>] (mxc_v4l2out_do_ioctl+0x4bc/0xea0) from [<802f5218>] (video_usercop
y+0x1f0/0x31c)
[<802f5218>] (video_usercopy+0x1f0/0x31c) from [<802f0570>] (v4l2_ioctl+0x50/0x5
c)
[<802f0570>] (v4l2_ioctl+0x50/0x5c) from [<800cfbb0>] (vfs_ioctl+0x7c/0xac)
[<800cfbb0>] (vfs_ioctl+0x7c/0xac) from [<800d021c>] (do_vfs_ioctl+0x548/0x594)
[<800d021c>] (do_vfs_ioctl+0x548/0x594) from [<800d02a0>] (sys_ioctl+0x38/0x5c)
[<800d02a0>] (sys_ioctl+0x38/0x5c) from [<80033f80>] (ret_fast_syscall+0x0/0x30)
Mem-info:
Normal per-cpu:
CPU 0: hi: 18, btch: 3 usd: 0
active_anon:2573 inactive_anon:226 isolated_anon:0
active_file:650 inactive_file:3713 isolated_file:0
unevictable:0 dirty:0 writeback:0 unstable:0
free:685 slab_reclaimable:599 slab_unreclaimable:811
mapped:2100 shmem:12 pagetables:247 bounce:0
Normal free:2740kB min:1016kB low:1268kB high:1524kB active_anon:10292kB inactiv
e_anon:904kB active_file:2600kB inactive_file:14852kB unevictable:0kB isolated(a
non):0kB isolated(file):0kB present:65024kB mlocked:0kB dirty:0kB writeback:0kB
mapped:8400kB shmem:48kB slab_reclaimable:2396kB slab_unreclaimable:3244kB kerne
l_stack:448kB pagetables:988kB unstable:0kB bounce:0kB writeback_tmp:0kB pages_s
canned:0 all_unreclaimable? no
lowmem_reserve[]: 0 0 0
Normal: 25*4kB 12*8kB 11*16kB 10*32kB 6*64kB 3*128kB 1*256kB 0*512kB 1*1024kB 0*
2048kB 0*4096kB 0*8192kB 0*16384kB = 2740kB
4375 total pagecache pages
0 pages in swap cache
Swap cache stats: add 0, delete 0, find 0/0
Free swap = 0kB
Total swap = 0kB
16384 pages of RAM
789 free pages
2388 reserved pages
1258 slab pages
4003 pages shared
0 pages swap cached
dma_alloc_coherent failed.
[Stopped ][Vol=01][00:00:00/00:00:00][fps:0]allocated software buffer
sk+0x508/0x55c)
+0xf0/0x2a8)
/0x60)
ers+0x28/0x84)
ioctl+0x4bc/0xea0)
y+0x1f0/0x31c)
c)
Mem-info:
Normal per-cpu:
active_anon:1381 inactive_anon:1420 isolated_anon:0
active_file:0 inactive_file:507 isolated_file:0
free:4924 slab_reclaimable:206 slab_unreclaimable:819
mapped:113 shmem:12 pagetables:247 bounce:0
Normal free:19696kB min:1016kB low:1268kB high:1524kB active_anon:5524kB inactiv
e_anon:5680kB active_file:0kB inactive_file:2028kB unevictable:0kB isolated(anon
):0kB isolated(file):0kB present:65024kB mlocked:0kB dirty:0kB writeback:0kB map
ped:452kB shmem:48kB slab_reclaimable:824kB slab_unreclaimable:3276kB kernel_sta
ck:448kB pagetables:988kB unstable:0kB bounce:0kB writeback_tmp:0kB pages_scanne
Normal: 114*4kB 421*8kB 276*16kB 148*32kB 61*64kB 14*128kB 0*256kB 0*512kB 1*102
4kB 0*2048kB 0*4096kB 0*8192kB 0*16384kB = 19696kB
519 total pagecache pages
Free swap = 0kB
Total swap = 0kB
16384 pages of RAM
5028 free pages
2388 reserved pages
870 slab pages
122 pages shared
0 pages swap cached
allocated software buffergplay: page allocation failure. order:8, mode:0xd1
sk+0x508/0x55c)
+0xf0/0x2a8)
/0x60)
ers+0x28/0x84)
ioctl+0x4bc/0xea0)
y+0x1f0/0x31c)
c)
Mem-info:
Normal per-cpu:
active_anon:1382 inactive_anon:1420 isolated_anon:0
active_file:0 inactive_file:674 isolated_file:0
free:4894 slab_reclaimable:206 slab_unreclaimable:821
mapped:192 shmem:12 pagetables:248 bounce:0
Normal free:19576kB min:1016kB low:1268kB high:1524kB active_anon:5528kB inactiv
e_anon:5680kB active_file:0kB inactive_file:2696kB unevictable:0kB isolated(anon
ped:768kB shmem:48kB slab_reclaimable:824kB slab_unreclaimable:3284kB kernel_sta
ck:448kB pagetables:992kB unstable:0kB bounce:0kB writeback_tmp:0kB pages_scanne
Normal: 38*4kB 380*8kB 274*16kB 149*32kB 61*64kB 14*128kB 2*256kB 0*512kB 1*1024
kB 0*2048kB 0*4096kB 0*8192kB 0*16384kB = 19576kB
686 total pagecache pages
Free swap = 0kB
Total swap = 0kB
16384 pages of RAM
4998 free pages
2388 reserved pages
871 slab pages
206 pages shared
0 pages swap cached
sk+0x508/0x55c)
+0xf0/0x2a8)
/0x60)
ers+0x28/0x84)
ioctl+0x4bc/0xea0)
y+0x1f0/0x31c)
c)
Mem-info:
Normal per-cpu:
active_anon:1383 inactive_anon:1420 isolated_anon:0
active_file:0 inactive_file:194 isolated_file:0
free:5233 slab_reclaimable:205 slab_unreclaimable:821
mapped:24 shmem:12 pagetables:248 bounce:0
Normal free:20932kB min:1016kB low:1268kB high:1524kB active_anon:5532kB inactiv
e_anon:5680kB active_file:0kB inactive_file:776kB unevictable:0kB isolated(anon)
:0kB isolated(file):0kB present:65024kB mlocked:0kB dirty:0kB writeback:0kB mapp
ed:96kB shmem:48kB slab_reclaimable:820kB slab_unreclaimable:3284kB kernel_stack
:448kB pagetables:992kB unstable:0kB bounce:0kB writeback_tmp:0kB pages_scanned:
Normal: 409*4kB 414*8kB 275*16kB 150*32kB 60*64kB 13*128kB 1*256kB 0*512kB 1*102
4kB 0*2048kB 0*4096kB 0*8192kB 0*16384kB = 20932kB
206 total pagecache pages
Free swap = 0kB
Total swap = 0kB
16384 pages of RAM
5337 free pages
2388 reserved pages
870 slab pages
49 pages shared
0 pages swap cached
sk+0x508/0x55c)
+0xf0/0x2a8)
/0x60)
ers+0x28/0x84)
ioctl+0x4bc/0xea0)
y+0x1f0/0x31c)
c)
Mem-info:
Normal per-cpu:
active_file:0 inactive_file:541 isolated_file:0
free:5021 slab_reclaimable:205 slab_unreclaimable:827
mapped:134 shmem:12 pagetables:248 bounce:0
Normal free:20084kB min:1016kB low:1268kB high:1524kB active_anon:5532kB inactiv
e_anon:5680kB active_file:0kB inactive_file:2164kB unevictable:0kB isolated(anon
ped:536kB shmem:48kB slab_reclaimable:820kB slab_unreclaimable:3308kB kernel_sta
Normal: 75*4kB 415*8kB 275*16kB 151*32kB 61*64kB 14*128kB 2*256kB 0*512kB 1*1024
kB 0*2048kB 0*4096kB 0*8192kB 0*16384kB = 20084kB
553 total pagecache pages
Free swap = 0kB
Total swap = 0kB
16384 pages of RAM
5125 free pages
2388 reserved pages
872 slab pages
165 pages shared
0 pages swap cached
Wait status change from 2 to 4
sk+0x508/0x55c)
+0xf0/0x2a8)
/0x60)
ers+0x28/0x84)
ioctl+0x4bc/0xea0)
y+0x1f0/0x31c)
c)
Mem-info:
Normal per-cpu:
active_anon:1384 inactive_anon:1420 isolated_anon:0
active_file:0 inactive_file:238 isolated_file:0
free:5173 slab_reclaimable:205 slab_unreclaimable:823
mapped:36 shmem:12 pagetables:248 bounce:0
Normal free:20692kB min:1016kB low:1268kB high:1524kB active_anon:5536kB inactiv
e_anon:5680kB active_file:0kB inactive_file:952kB unevictable:0kB isolated(anon)
ed:144kB shmem:48kB slab_reclaimable:820kB slab_unreclaimable:3292kB kernel_stac
k:448kB pagetables:992kB unstable:0kB bounce:0kB writeback_tmp:0kB pages_scanned
:smileylaugh: all_unreclaimable? no
Normal: 363*4kB 411*8kB 275*16kB 151*32kB 61*64kB 14*128kB 0*256kB 0*512kB 1*102
4kB 0*2048kB 0*4096kB 0*8192kB 0*16384kB = 20692kB
263 total pagecache pages
Free swap = 0kB
Total swap = 0kB
16384 pages of RAM
5277 free pages
2388 reserved pages
871 slab pages
74 pages shared
0 pages swap cached
[Stopped ][Vol=01][00:00:00/00:00:00][fps:0]gplay: page allocation failure. ord
er:8, mode:0xd1
sk+0x508/0x55c)
+0xf0/0x2a8)
/0x60)
ers+0x28/0x84)
ioctl+0x4bc/0xea0)
y+0x1f0/0x31c)
c)
Mem-info:
Normal per-cpu:
active_file:0 inactive_file:749 isolated_file:0
free:4677 slab_reclaimable:205 slab_unreclaimable:821
mapped:235 shmem:12 pagetables:248 bounce:0
Normal free:18708kB min:1016kB low:1268kB high:1524kB active_anon:5536kB inactiv
e_anon:5680kB active_file:0kB inactive_file:2996kB unevictable:0kB isolated(anon
ped:940kB shmem:48kB slab_reclaimable:820kB slab_unreclaimable:3284kB kernel_sta
Normal: 27*4kB 327*8kB 275*16kB 150*32kB 60*64kB 13*128kB 1*256kB 0*512kB 1*1024
kB 0*2048kB 0*4096kB 0*8192kB 0*16384kB = 18708kB
761 total pagecache pages
Free swap = 0kB
Total swap = 0kB
16384 pages of RAM
4781 free pages
2388 reserved pages
870 slab pages
247 pages shared
0 pages swap cached
sk+0x508/0x55c)
+0xf0/0x2a8)
/0x60)
ers+0x28/0x84)
ioctl+0x4bc/0xea0)
y+0x1f0/0x31c)
c)
Mem-info:
Normal per-cpu:
active_file:0 inactive_file:456 isolated_file:0
free:5107 slab_reclaimable:205 slab_unreclaimable:825
mapped:105 shmem:12 pagetables:248 bounce:0
Normal free:20428kB min:1016kB low:1268kB high:1524kB active_anon:5536kB inactiv
e_anon:5680kB active_file:0kB inactive_file:1824kB unevictable:0kB isolated(anon
ped:420kB shmem:48kB slab_reclaimable:820kB slab_unreclaimable:3300kB kernel_sta
Normal: 161*4kB 415*8kB 275*16kB 151*32kB 61*64kB 14*128kB 2*256kB 0*512kB 1*102
4kB 0*2048kB 0*4096kB 0*8192kB 0*16384kB = 20428kB
468 total pagecache pages
Free swap = 0kB
Total swap = 0kB
16384 pages of RAM
5211 free pages
2388 reserved pages
871 slab pages
115 pages shared
0 pages swap cached
sk+0x508/0x55c)
+0xf0/0x2a8)
/0x60)
ers+0x28/0x84)
ioctl+0x4bc/0xea0)
y+0x1f0/0x31c)
c)
Mem-info:
Normal per-cpu:
active_anon:1391 inactive_anon:1420 isolated_anon:0
active_file:0 inactive_file:615 isolated_file:0
free:4802 slab_reclaimable:205 slab_unreclaimable:821
mapped:184 shmem:12 pagetables:249 bounce:0
Normal free:19208kB min:1016kB low:1268kB high:1524kB active_anon:5564kB inactiv
e_anon:5680kB active_file:0kB inactive_file:2460kB unevictable:0kB isolated(anon
ped:736kB shmem:48kB slab_reclaimable:820kB slab_unreclaimable:3284kB kernel_sta
ck:456kB pagetables:996kB unstable:0kB bounce:0kB writeback_tmp:0kB pages_scanne
Normal: 42*4kB 382*8kB 275*16kB 150*32kB 60*64kB 13*128kB 1*256kB 0*512kB 1*1024
kB 0*2048kB 0*4096kB 0*8192kB 0*16384kB = 19208kB
627 total pagecache pages
Free swap = 0kB
Total swap = 0kB
16384 pages of RAM
4907 free pages
2388 reserved pages
870 slab pages
190 pages shared
0 pages swap cached
>>V4L_SINK: Actually buffer status:
hardware buffer : 0
software buffer : 0
[Stopped ][Vol=01][00:00:00/00:00:00][fps:0]Wait status change from 2 to 4
[Stopped ][Vol=01][00:00:00/00:00:00][fps:0][Stopped ][Vol=01][00:00:00/00:00:00][fps:0]Wait status change from 2 to 4
er:8, mode:0xd1
sk+0x508/0x55c)
+0xf0/0x2a8)
/0x60)
[<80039008>] (dma_alloc_coherent+0x54/0x60) from [<80327880>] (vpu_alloc_dma_buf
fer+0x2c/0x50)
[<80327880>] (vpu_alloc_dma_buffer+0x2c/0x50) from [<80327f1c>] (vpu_ioctl+0xc8/
0x798)
[<80327f1c>] (vpu_ioctl+0xc8/0x798) from [<800cfbb0>] (vfs_ioctl+0x7c/0xac)
Mem-info:
Normal per-cpu:
active_anon:1392 inactive_anon:1420 isolated_anon:0
active_file:0 inactive_file:0 isolated_file:0
free:5394 slab_reclaimable:205 slab_unreclaimable:819
mapped:0 shmem:12 pagetables:249 bounce:0
Normal free:21576kB min:1016kB low:1268kB high:1524kB active_anon:5568kB inactiv
e_anon:5680kB active_file:0kB inactive_file:0kB unevictable:0kB isolated(anon):0
kB isolated(file):0kB present:65024kB mlocked:0kB dirty:0kB writeback:0kB mapped
:0kB shmem:48kB slab_reclaimable:820kB slab_unreclaimable:3276kB kernel_stack:45
6kB pagetables:996kB unstable:0kB bounce:0kB writeback_tmp:0kB pages_scanned:0 a
Normal: 594*4kB 412*8kB 274*16kB 150*32kB 59*64kB 11*128kB 2*256kB 0*512kB 1*102
4kB 0*2048kB 0*4096kB 0*8192kB 0*16384kB = 21576kB
12 total pagecache pages
Free swap = 0kB
Total swap = 0kB
16384 pages of RAM
5499 free pages
2388 reserved pages
869 slab pages
0 pages shared
0 pages swap cached
Physical memory allocation error!
[ERR] mem allocation failed!
Debug: Allocation of the Frame Buffers Failed
Error: fatal error
[Stopped ][Vol=01][00:00:00/00:00:00][fps:0][Stopped ][Vol=01][00:00:00/00:00:00][fps:0]xWait status change from 2 to 4
[Stopped ][Vol=01][00:00:00/00:00:00][fps:0] Aborted by signal Interrupt...
Looking at your log I see that you face a baud rate issue that was part of an old U-boot version.
Please upgrade your U-boot. You can use the latest one from FSL or even the mainline version.
This will fix many of your issues. Also, try using 11.09 kernel as well.
Fabio Estevam
thanks for your reply but i stream the 640x480 resolution using gstreamer now its working fine but when i tried to capture the live recording using rtsp stream it shows the following errors can you help me with this
NOTE: for your convenience i had send you the logfile and one more important thing is i am using WOWZA MEDIA SERVER in the other end for streaming the video from camera
COMMAND: gst-launch rtspsrc location=rtsp://192.168.0.50:1935/media/video0 ! decodebin ! mfw_mpeg4aspdecoder ! filesink location=file
ERROR:
MPEG4_ASP_D_01.02.01 build on Apr 19 2011 19:13:51.
MFW_GST_MPEG4ASP_DECODER_PLUGIN 2.0.3 build on Sep 29 2011 15:41:19.
Setting pipeline to PAUSED ...
ERROR: Pipeline doesn't want to pause.
ERROR: from element /GstPipeline:pipeline0/GstRTSPSrc:rtspsrc0: Resource not fou
nd.
Additional debug info:
gstrtspsrc.c(3832): gst_rtspsrc_send (): /GstPipeline:pipeline0/GstRTSPSrc:rtsps
rc0:
Not Found
Setting pipeline to NULL ...
(gst-launch-0.10:2233): GStreamer-CRITICAL **: gst_mini_object_unref: assertion
`mini_object != NULL' failed
You should use mfw_vpudecoder instead of mfw_mpeg4aspdecoder.
mfw_vpudecoder uses the hardware decoder (VPU), and mfw_mpeg4aspdecoder is a software decoder.
Fabio Estevam
hi Fabio Estevam
same error is repeating again i think some other problem is running
root@freescale ~$ gst-launch rtspsrc location=rtsp://192.168.0.50:1935/media/vid
eo0 ! decodebin ! mfw_vpudecoder ! filesink location=file
nd.
rc0:
Not Found
>>VPU_DEC: State: Ready to Null
Freeing pipeline ...
[--->FINALIZE vpu_dec
root@freescale ~$
I didn´t work with rtspsrc, but when I worked with udpsrc it was needed to include caps for the source.
Take a look on this
https://community.freescale.com/docs/DOC-1560
Don´t you need a demuxer between rtspsrc and decodebin?
hi daiane angolini
thanks for your reply i had look at the link you specified, i am working on it let you know in one or two days
and i want to clarify one more doubt. i am using the imx535qsb board in that we include the camera [ov5640] interface application in that we successfully captured the 640x480 video
but when i supposed to capture the 720p image its working fine if i am capturing the 720p video its divided into four frames in a single window and also the video is running so fastly
NOTE: for your convenience i had attached the sample video have a look at that
shanmugam
Thanks for the video. I can remember I already saw this issue...
Could you, please, tell me again what is the source code version you´re using? For both kernel and gstreamer plugins rellated.
kernel version is 2.6.35
Gstreamer version is IMX_MMCODECS_11.09 downloaded from the freescale website
Find the log from here https://community.freescale.com/docs/DOC-93586
Sorry. I got confused with your log. (would be better to have it a attached file?)
Was you able to build LTIB rootfs mm packages included?
hi daiane
find the log file in this link GSTREAMER LOG
yes i can able to build the file system and also i 've checked it by giving basic gst commands such as gst-inspect, gst-launch --gst-help, version etc
