Hi All,
I am trying to boot the wince image my SD card. I have configure to run the image from SD card,
[5] Select Boot Device : NK from SD/MMC
However, the booting process stuck at reading the NK image
Initiating image launch in 0 seconds.
Launching flash image ...
INFO: Using device name: 'MX2865535'
INFO: Reading NK image to SDHC (please wait)...
Thank you for your help!
Liang
Dear Adeneo Support Team,
sorry for the late reply! I just found out that I have reply from you!
1. Yes, I am building my own binaries and I did replaced all the binaries on the SD card
2. I do not whether this is the hardware revision number you are looking for, MX2865535
3. I have a display connected to the motherboard.
Thank you,
Liang
Deactivated user, can you help with this question? Thanks.
Deactivated user are you available to help on this case?
