On the bottom part of IMX6qSabreAuto board, there is a Wi-Fi ® SD Card Slot and BT Module Connector.
I want to know which Wifi SD card and which BT module is most suitable and is easily available for this board. Which devices are supported ?.How to make it working ?
I have seen that Broadcom BCM4339 is supported. But I couldnt find any devices or daughter boards for imx6qsabreauto board. Kindly suggest some.
I am using linux OS
Hi Saseendranath
please refer to
wireless.murata.com/eng/products/rf-modules-1/wi-fi-bluetooth-for-freescale-i-mx.html
also after registering vendor of modules provide additional documents for connection
and usage like below
wireless.murata.com/datasheet?/RFM/data/murata_quick_start_guide_linux.pdf
