Both i.MX 7ULP EVK (Qualcomm QCA9377 WiFi/Bluetooth module) and EVKB (Broadcom BCM43430 WiFi/Bluetooth module) boards have MFi connector. We have EVK board but I could not find any information in public documentation whether QCA9377 supports MFi. MFi chip is successfully detected on I2C7 bus.
Could someone give any hints how MFi support can be enabled on either EVK or EVKB board?
Solved! Go to Solution.
Hi Marius,
The information about MFi related designs is available under NDA. We would recommend contacting your local Sales/Distributor or directly with Mike Toh through the “MFi Program portal” on the following link:
MFi Accessory Software Development Kit (SDK) | NXP
Hope this will be useful for you.
Best regards!
/Carlos
Hi Marius,
Best regards!
/Carlos
