Dear All,
Hello.
My customer is considering that changing the VGEN4's voltage from 1.8V to 3.3V via I2C in operation.
But, the VGEN4 output to NVCC_CSI & NVCC_EIM in i.MX6DQ.
Is it possible to accept the changing the voltage for NVCC_CSI & NVCC_EIM of i.MX6DQ in operation?
Keita
Solved! Go to Solution.
Yes, it is possible to change the voltage for NVCC_CSI & NVCC_EIM of i.MX6DQ in operation,
assuming all voltages are within the specified range, and external parts, connected to the i.MX6 pins,
powered via NVCC_CSI & NVCC_EIM, are tolerant to the applied voltages.
MMPF0100 I2C programming (alternatives)
https://community.nxp.com/thread/343843
Yuri
Note: If this post answers your question, please click the Correct
Answer button. Thank you!
Yuri
