About Cortex-M4 in i.MX7 Software Video Encode Capability
1,359 次查看
george
Senior Contributor II
Dear all,
Currently, we have planned the product for the image analysis used i.MX7.
We use CA7 only for analysis, and CM4 does mpeg encoding(mpeg) of the input from parallel Camera, and then passes it as UVC to PC.
What performance is mpeg encode of VGA size in the above application using CM4?
What frame rate can be processed?
If there are benchmarks which is reference, please let me know.
George
标签 (4)
945 次查看
art
The CM4 core of i.MX7 series processors has not enough performance for such a complicated and resource-intensive task as on-the-fly mpeg encoding. So, no benchmark metering has ever been performed for such a case.
Artur
4 回复数
946 次查看
art
Artur
945 次查看
george
Dear Artur,
Thank you for the reply.
We understood your advice.
But I think that we need to try it.
Please tell, if you have the information which is a help to for it.
For example, is there any sample code to refer?
George
945 次查看
art
Unfortunately, no, there is no such a reference code and no any estimation for such a task.
945 次查看
george
George
