Dear All,
Hello.
Refer to Table 2-6. Power and decouple recommendations in IMX6DQ6SDLHDG (Rev.1).
Only one 22 μF bulk capacitor should be connected to each of these on-chip LDO regulator outputs:
- VDD_ARM_CAP
- VDDARM23_CAP
- VDD_SOC_CAP
- VDD_PU_CAP
I'd like to know why does freescale recommend the 22 μF bulk capacitor.
We'd like to use the 10 μF bulk capacitor.
What problem is there, when the capacitor smaller than the recommendation size?
Keita
Hi Keita
this value is choosen due to ripple requirements given in
5% Vp-p for Maximum ripple voltage requirements.
Yes, one can use smaller size capacitor.
Dear Igor,
Hello.
Thank you for your prompt reply.
Let me clarify my understanding.
When we select the smaller capacity from 22uF (recommendation), is it OK the we keep a 5% Vp-p for Maximum ripple voltage requirements?
By choosing the small capacitor connected with VDD_xx_CAP, is there another problem except the ripple noise?
Keita
Hi Keita
this is customer responsibility to provide
5% Vp-p for Maximum ripple voltage requirements with
smaller capacitor value .
22uF value is verified and provides that.
Hi Igor,
Thank you for your reply.
OK. Thanks!
Keita
