imx-test-3.0.35-4.1.0中vpu_test怎样解码h264视频?解码后的yuv怎么保存?求教,谢谢!
Solved! Go to Solution.
you can read the source code to understand how it works.
To get the source code, you can type this command.
./ltib -p imx-test -m prep
then the source code will be extracted in the folder : ltib/rpm/BUILD/imx-test-3.0.35/
you can modify the source code and then build it again. To re-build it, please type
./ltib -p imx-test -m scbuild
Then install it to rootfs again.
./ltib -p imx-test -m scdeploy
For more information, please download the BSP documentation
There is i.MX_6Dual6Quad_VPU_API_Reference_Manual.pdf, in section 4.4.2 VPU Example Application talk about the VPU test in details.
Thank you for your answer,I have reviewed the took imx - test source code, and the problem has been solved。
