Running a Script in U-boot
Pre-requisites:
  • An TFTP server
  • U-boot with TFTP capabilities
If you need to run a script (for example, running multiple setenv's commands) in U-boot for many boards, you can instead create a U-boot script (called script image), place it into your tftp folder, then ask U-boot to fetch it and run it. For example, you want to run the following setenv instructions
setenv loadaddr 0x10800000
setenv bootargs_base 'setenv bootargs console=ttymxc0,115200'
setenv bootargs_mmc 'setenv bootargs ${bootargs} root=/dev/mmcblk0p1 rootwait rw video=mxcfb0:dev=ldb,LDB-XGA,if=RGB666'
setenv bootcmd_mmc 'run bootargs_base bootargs_mmc;mmc dev 3;mmc read ${loadaddr} 0x800 0x2000;bootm'
run bootcmd_mmc
save it into a file, I choose the name 'myscript'; under your <U-boot folder>/tools, execute
$ mkimage -T script -C none -n 'My Script' -d myscript myscript.img
and copy myscript.img file into your TFTP folder.
On the target, set the following two variables (serverip and bootcmd)
# Set the Server IP, where the TFTP server is running
setenv serverip <the server IP> # In case the server IP is static, you can place this line into the U-boot script
setenv scriptaddr 0x10700000
setenv scriptname myscript.img
# You can use either TFTP or DHCP
setenv tftpcmd tftp # or 'dhcp'  in case you want to use dhcp U-boot command
# Not needed for dhcp
setenv ipaddr <the target IP> # needed in case the command tftp is used
setenv gatewayip <the Gateway IP> # needed in case the command tftp is used
setenv bootcmd '${tftpcmd} ${scriptaddr} ${scriptname}; source ${scriptaddr}'
saveenv
reset
That is all you need to do.
Enjoy U-booting!
评论
I have a custom made board of i.MX6, i have to add a script which test RAM working, for that i have to copy my script in SD/MMC(8GB) card,this testing will be done in uboot, now i need some help on this i have  created script file using mkimage. for this where i can copy and how to run that script at what address location. NOTE: i can't use tftp/dhcp because this board doesn't have tftp/dhcp support.
%3CLINGO-SUB%20id%3D%22lingo-sub-1111494%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9C%A8%20U-boot%20%E4%B8%AD%E8%BF%90%E8%A1%8C%E8%84%9A%E6%9C%AC%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1111494%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%22%3E%E5%85%88%E5%86%B3%E6%9D%A1%E4%BB%B6%EF%BC%9A%20%3C%2FSPAN%3E%3C%2FP%3E%3CUL%3E%3CLI%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%22%3ETFTP%20%E6%9C%8D%E5%8A%A1%E5%99%A8%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%22%3E%E5%85%B7%E6%9C%89%20TFTP%20%E5%8A%9F%E8%83%BD%E7%9A%84%20U-boot%3C%2FSPAN%3E%3C%2FLI%3E%3C%2FUL%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%22%3E%E5%A6%82%E6%9E%9C%E6%82%A8%E9%9C%80%E8%A6%81%E5%9C%A8%20U-boot%20%E4%B8%AD%E4%B8%BA%E8%AE%B8%E5%A4%9A%E6%9D%BF%E8%BF%90%E8%A1%8C%E8%84%9A%E6%9C%AC%EF%BC%88%E4%BE%8B%E5%A6%82%EF%BC%8C%E8%BF%90%E8%A1%8C%E5%A4%9A%E4%B8%AA%20setenv%20%E7%9A%84%E5%91%BD%E4%BB%A4%EF%BC%89%EF%BC%8C%E6%82%A8%E5%8F%AF%E4%BB%A5%E5%88%9B%E5%BB%BA%E4%B8%80%E4%B8%AA%20U-boot%20%E8%84%9A%E6%9C%AC%EF%BC%88%E7%A7%B0%E4%B8%BA%E8%84%9A%E6%9C%AC%E6%98%A0%E5%83%8F%EF%BC%89%EF%BC%8C%E5%B0%86%E5%85%B6%E6%94%BE%E5%85%A5%E6%82%A8%E7%9A%84%20tftp%20%E6%96%87%E4%BB%B6%E5%A4%B9%E4%B8%AD%EF%BC%8C%E7%84%B6%E5%90%8E%E8%A6%81%E6%B1%82%20U-boot%20%E8%8E%B7%E5%8F%96%E5%B9%B6%E8%BF%90%E8%A1%8C%E5%AE%83%E3%80%82%E4%BE%8B%E5%A6%82%EF%BC%8C%E6%82%A8%E8%A6%81%E8%BF%90%E8%A1%8C%E4%BB%A5%E4%B8%8B%20setenv%20%E6%8C%87%E4%BB%A4%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%22%3E%3CEM%3Esetenv%20loadaddr%200x10800000%3C%2FEM%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%22%3E%3CEM%3Esetenv%20bootargs_base%20'setenv%20bootargs%20console%3Dttymxc0%2C115200'%3C%2FEM%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%22%3E%3CEM%3Esetenv%20bootargs_mmc%20'setenv%20bootargs%20%24%7Bbootargs%7D%20root%3D%2Fdev%2Fmmcblk0p1%20rootwait%20rw%20video%3Dmxcfb0%3Adev%3Dldb%2CLDB-XGA%2Cif%3DRGB666'%3C%2FEM%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%22%3E%3CEM%20style%3D%22color%3A%20black%3B%22%3E%3CEM%3E%3CEM%3Esetenv%20bootcmd_mmc'%E8%BF%90%E8%A1%8C%20bootargs_base%20bootargs_mmc%EF%BC%9Bmmc%20dev%203%EF%BC%9Bmmc%20%E8%AF%BB%E5%8F%96%24%7Bloadaddr%7D%200x800%200x2000%EF%BC%9Bbootm'%3C%2FEM%3E%3C%2FEM%3E%3C%2FEM%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%22%3E%3CEM%3E%3CEM%3E%3CSPAN%20style%3D%22color%3A%20black%3B%22%3E%E8%BF%90%E8%A1%8C%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20black%3B%22%3Ebootcmd_mmc%3C%2FSPAN%3E%3C%2FEM%3E%3C%2FEM%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%22%3E%3CEM%3E%3CBR%20%2F%3E%3C%2FEM%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%22%3E%E5%B0%86%E5%85%B6%E4%BF%9D%E5%AD%98%E5%88%B0%E6%96%87%E4%BB%B6%E4%B8%AD%EF%BC%8C%E6%88%91%E9%80%89%E6%8B%A9%E5%90%8D%E7%A7%B0%E2%80%9C%3CEM%3E%20myscript%3C%2FEM%3E%20%E2%80%9D%3B%20%E5%9C%A8%E4%BD%A0%E7%9A%84%3CEM%3E%3CU-BOOT%20folder%3D%22%22%3E%20%2Ftools%3C%2FU-BOOT%3E%3C%2FEM%3E%20%E4%B8%8B%EF%BC%8C%E6%89%A7%E8%A1%8C%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%22%3E%3CEM%3E%24%20mkimage%20-T%20script%20-C%20none%20-n%20'%E6%88%91%E7%9A%84%E8%84%9A%E6%9C%AC'%20-d%20myscript%20myscript.img%3C%2FEM%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%22%3E%E5%B9%B6%E5%B0%86%3CEM%3Emyscript.img%3C%2FEM%3E%E6%96%87%E4%BB%B6%E5%A4%8D%E5%88%B6%E5%88%B0%E6%82%A8%E7%9A%84%20TFTP%20%E6%96%87%E4%BB%B6%E5%A4%B9%E4%B8%AD%E3%80%82%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%22%3E%E5%9C%A8%E7%9B%AE%E6%A0%87%E4%B8%8A%EF%BC%8C%E8%AE%BE%E7%BD%AE%E4%BB%A5%E4%B8%8B%E4%B8%A4%E4%B8%AA%E5%8F%98%E9%87%8F%EF%BC%88%20%3CEM%3Eserverip%3C%2FEM%3E%E5%92%8C%3CEM%3Ebootcmd%3C%2FEM%3E%20%EF%BC%89%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%22%3E%23%20%E8%AE%BE%E7%BD%AE%E8%BF%90%E8%A1%8C%20TFTP%20%E6%9C%8D%E5%8A%A1%E5%99%A8%E7%9A%84%E6%9C%8D%E5%8A%A1%E5%99%A8%20IP%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%22%3E%3CEM%3Esetenv%20serverip%3CTHE%20server%3D%22%22%20ip%3D%22%22%3E%20%23%20%E5%A6%82%E6%9E%9C%E6%9C%8D%E5%8A%A1%E5%99%A8%20IP%20%E6%98%AF%E9%9D%99%E6%80%81%E7%9A%84%EF%BC%8C%E5%88%99%E5%8F%AF%E4%BB%A5%E5%B0%86%E6%AD%A4%E8%A1%8C%E6%94%BE%E5%85%A5%20U-boot%20%E8%84%9A%E6%9C%AC%E4%B8%AD%3C%2FTHE%3E%3C%2FEM%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%22%3E%3CEM%3Esetenv%20scriptaddr%20%3CEM%3E0x10700000%3C%2FEM%3E%3C%2FEM%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%22%3E%3CEM%3Esetenv%20scriptname%20myscript.img%3C%2FEM%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%22%3E%3CEM%3E%3CBR%20%2F%3E%3C%2FEM%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%22%3E%3CEM%3E%23%20%E6%82%A8%E5%8F%AF%E4%BB%A5%E4%BD%BF%E7%94%A8%20TFTP%20%E6%88%96%20DHCP%3C%2FEM%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%22%3E%3CEM%3Esetenv%20tftpcmd%20tftp%20%23%20%E6%88%96%E8%80%85%3C%2FEM%3E%3CEM%3E%3CEM%3E%E5%A6%82%E6%9E%9C%E4%BD%A0%E6%83%B3%E4%BD%BF%E7%94%A8%20dhcp%20U-boot%20%E5%91%BD%E4%BB%A4%EF%BC%8C%3C%2FEM%3E%3C%2FEM%3E%E5%88%99%E8%BE%93%E5%85%A5%E2%80%9Cdhcp%E2%80%9D%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%22%3E%3CEM%3E%3CEM%3E%3CBR%20%2F%3E%3C%2FEM%3E%3C%2FEM%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%22%3E%3CEM%3E%23%20DHCP%20%E4%B8%8D%E9%9C%80%E8%A6%81%3CBR%20%2F%3E%3C%2FEM%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%22%3E%3CEM%3Esetenv%20ipaddr%3CTHE%20target%3D%22%22%20ip%3D%22%22%3E%20%23%20%E5%A6%82%E6%9E%9C%E4%BD%BF%E7%94%A8%E5%91%BD%E4%BB%A4%20tftp%20%E5%88%99%E9%9C%80%E8%A6%81%3C%2FTHE%3E%3C%2FEM%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%22%3E%3CEM%3Esetenv%20gateip%3CTHE%20gateway%3D%22%22%20ip%3D%22%22%3E%3CEM%3E%20%23%20%E5%A6%82%E6%9E%9C%E4%BD%BF%E7%94%A8%E5%91%BD%E4%BB%A4%20tftp%20%E5%88%99%E9%9C%80%E8%A6%81%3C%2FEM%3E%3CBR%20%2F%3E%3C%2FTHE%3E%3C%2FEM%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%22%3E%3CEM%3Esetenv%20bootcmd%20'%24%7Btftpcmd%7D%20%24%7Bscriptaddr%7D%20%24%7Bscriptname%7D%3B%20source%20%24%7Bscriptaddr%7D'%3C%2FEM%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%22%3E%3CEM%3Esaveenv%3C%2FEM%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%22%3E%3CEM%3E%E9%87%8D%E7%BD%AE%3CBR%20%2F%3E%3C%2FEM%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%22%3E%3CEM%3E%3CBR%20%2F%3E%3C%2FEM%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%22%3E%3CEM%3E%E8%BF%99%E5%B0%B1%E6%98%AF%E6%82%A8%E9%9C%80%E8%A6%81%E5%81%9A%E7%9A%84%E5%85%A8%E9%83%A8%E4%BA%8B%E6%83%85%E3%80%82%3CBR%20%2F%3E%3C%2FEM%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%22%3E%3CEM%3E%3CBR%20%2F%3E%3C%2FEM%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%22%3E%E4%BA%AB%E5%8F%97%20U-booting%EF%BC%81%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1111495%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%9C%A8%20U-boot%20%E4%B8%AD%E8%BF%90%E8%A1%8C%E8%84%9A%E6%9C%AC%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1111495%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E6%88%91%E6%9C%89%E4%B8%80%E5%9D%97%E5%AE%9A%E5%88%B6%E7%9A%84%20i.MX6%20%E6%9D%BF%EF%BC%8C%E6%88%91%E5%BF%85%E9%A1%BB%E6%B7%BB%E5%8A%A0%E4%B8%80%E4%B8%AA%E6%B5%8B%E8%AF%95%20RAM%20%E5%B7%A5%E4%BD%9C%E7%9A%84%E8%84%9A%E6%9C%AC%EF%BC%8C%E4%B8%BA%E6%AD%A4%E6%88%91%E5%BF%85%E9%A1%BB%E5%B0%86%E6%88%91%E7%9A%84%E8%84%9A%E6%9C%AC%E5%A4%8D%E5%88%B6%E5%88%B0%20SD%2FMMC%EF%BC%888GB%EF%BC%89%E5%8D%A1%E4%B8%AD%EF%BC%8C%E8%BF%99%E4%B8%AA%E6%B5%8B%E8%AF%95%E5%B0%86%E5%9C%A8%20uboot%20%E4%B8%AD%E5%AE%8C%E6%88%90%EF%BC%8C%E7%8E%B0%E5%9C%A8%E6%88%91%E9%9C%80%E8%A6%81%E4%B8%80%E4%BA%9B%E5%B8%AE%E5%8A%A9%EF%BC%8C%E6%88%91%E5%B7%B2%E7%BB%8F%E4%BD%BF%E7%94%A8%20mkimage%20%E5%88%9B%E5%BB%BA%E4%BA%86%E8%84%9A%E6%9C%AC%E6%96%87%E4%BB%B6%E3%80%82%E4%B8%BA%E6%AD%A4%E6%88%91%E5%8F%AF%E4%BB%A5%E5%A4%8D%E5%88%B6%E5%93%AA%E9%87%8C%E4%BB%A5%E5%8F%8A%E5%A6%82%E4%BD%95%E5%9C%A8%E4%BB%80%E4%B9%88%E5%9C%B0%E5%9D%80%E4%BD%8D%E7%BD%AE%E8%BF%90%E8%A1%8C%E8%AF%A5%E8%84%9A%E6%9C%AC%E3%80%82%E6%B3%A8%E6%84%8F%EF%BC%9A%E6%88%91%E6%97%A0%E6%B3%95%E4%BD%BF%E7%94%A8%20tftp%2Fdhcp%EF%BC%8C%E5%9B%A0%E4%B8%BA%E8%AF%A5%E4%B8%BB%E6%9D%BF%E4%B8%8D%E6%94%AF%E6%8C%81%20tftp%2Fdhcp%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E
无评分
版本历史
最后更新:
‎10-15-2012 12:25 PM
更新人:
