TPM with 868MHz radio?
2,890 次查看
erichnast
I am aware of the FXTH870xD Tire Pressure Monitor Sensor which have a 433MHz radio.
My customer likes the product, but requires an 868MHz radio. Do you know if Freescale have such a part, or maybe working on a part with 868MHz radio?
Erich Nast
2,562 次查看
mihaidragnea
Hello Erich,
Freescale's TPM systems are working on 315/433 MHz ISM bands, there are no embedded TPM sensors with radio running at 868 MHz (at least I don't know any).
But we do have a very attractive MCU + radio SiP, called KW0x |Kinetis KW0x Sub-1 GHz Radio MCUs|Freescale
The core is a 32-bit ARM Cortex M0+ processor running up to 48 MHz, the system has 128KB of Flash memory and 16KB of RAM. The radio features set is also quite impressive. Please take a look and if your customer agrees a 2 chips design (TPM sensor + KW0x) then this might be a good option for you.
Kind Regards,
Mihai
5 回复数
2,563 次查看
mihaidragnea
Hello Erich,
Kind Regards,
Mihai
2,562 次查看
erichnast
Thanks Mihai,
Unfortunately my customer wants a complete single chip solution....thanks anyway,
Erich
2,562 次查看
jasonchiang
There are no embedded TPMS sensors with radio running at 868 MHz currently.
I am interested to know why your customer needs 868MHz instead of 315/434MHz.
We have FXTH87xx + KW01 demo code availabe  running 315/434MHz at
FXTH87|Tire Pressure Monitor Sensor|Freescale
2,562 次查看
erichnast
Good day,
Reason is that they already run an 868MHz radio in their current system, so would want to integrate the TPM into their existing network.
I have discussed option of doing a 433 to 868 bridge, but they not keen to do this.
They do currently use a TPM with 868Mhz radio, so I was hoping to replace it with a Freescale solution.
Erich Nast
FAE
erich.nast@avnet.eu
Block 3, Pinewood Office Park
33 Riley Rd, Woodmead, Sandton
Office:
011 319 8600
Cell:
082 372 6893
<https://www.facebook.com/pages/Avnet-Kopp-Pty-Ltd/131474643716078>
Facebook<https://www.facebook.com/pages/Avnet-Kopp-Pty-Ltd/131474643716078>
<https://plus.google.com/105159574006100776917/>
Google+<https://plus.google.com/105159574006100776917/>
<https://www.linkedin.com/company/663449>
LinkedIn<https://www.linkedin.com/company/663449>
<http://www.avnet.co.za/>
2,562 次查看
jasonchiang
Thanks for your valuable information.
