I didn't find any sample that supports the BLE5.0 Advertising extension feature in the latest K32W SDK (SDK version 2.6.3) while it can be found in KW38 latest SDK.
Does K32W support the BLE5.0 Advertising extension features?
Thanks so much!
Loi Tran
Solved! Go to Solution.
Hi Loi Tran,
Hope you are doing well. The K32W is Bluetooth LE 5 compliant, but it doesn’t support the extended advertisement, long-range, or the coded PHY.
Unfortunately, the K32W won't send an extended advertisement.
Ricardo
Hi Loi Tran,
Ricardo
