It is also not clear to use which*.srec file for Radio testing. I tried "MAC 2006 ZTC 115200 KW24D512-USB ASP_Radiotest.srec (as shown below). But I still dont see any signal at the SMA connector of Freedom Board.
Thanks.
Hi Zeshan,
It is not possible see the file, could you please try again.?
If you want to make a Radio testing, you can check the next link, the option build and run.
FRDM-KW24D512|Freedom Development Platform|Kinetis|NXP
Let me know if you have problems.
Mario
Hi Mario,
I highlight the firmware which I used to do Radio Testing. What could be the problem?
I dont understand which link you mean?
Zeshan
Hi Zeshan,
Could you please check the next document?, Quick Start, USB-KW24D512
http://www.nxp.com/files/32bit/doc/user_guide/USBKW24D512QSG.pdf?fsrch=1&sr=6&pageNum=1
Let me know, if you upload another example and the problem is the same
Best Regards
Mario
