Hello!
I am using PN7642. I would like to ask is it possible to use SPI that is connected to host interface pins ATX_A, ATX_B, ATX_C, ATX_D in master mode or it can be configured only to work in slave mode?
Thanks in advance!
Artem
Solved! Go to Solution.
Hello @artem_pn
Hope you are doing well.
Host Interface pins may be intended for SPI target functionality. SPI controller should have dedicated pins according to PN7642 Data Sheet, Section 8 pinning information.
Eduardo.
Hello @artem_pn
Eduardo.
Thank you!
