Because K32W is a new chip, it has the following problems:
1. Does the SWD interface on the K32W main board support Multilink (debug tool) download as usual?
2. If not support Multilink , what debug tool can be supported?
Hi Mario,
It's been a week since this question, is there any test result?
Hi Daniel,
Please accept my apologies for the late response.
Unfortunately, K32W is supporting the following probes:
Link2 debug probe with ARM’s CMSIS-DAP and SEGGER J-Link protocol options.
Boards user manual: https://www.nxp.com/docs/en/user-guide/UM11393%20.pdf
NXP open SDA J& link2:
OpenSDA Serial and Debug Adapter | NXP
Sorry for any inconvenience that this may cause you.
Mario
Hi Daniel,
I hope you are doing great.
Sorry for my late response, We are still working on it. We are facing some delays for all of this COVID Novel.
I will get back to you as soon as possible.
Mario
Hi Mario,
Multilink is urgent currently , can you help me check this function first?
This is the result of my test, for your reference.There will be an error message。
In addition, I used Multilink to test that KW41 can be loaded normally, which means that my Multilink can work without damage.
In other words,
SWD interface on the Carrier Main Board support via Multilink to download image to "LPC4322" or "K32W module chip" ?
Hi Daniel,
I am checking the Multilink support. I will get back to you as soon as possible.
Mario
Hi Daniel,
The mainboard provides an LPC4322 with CMSIS DAP firmware. you could use this tool for debugging purposes. Also, you can use an external LPC LINK 2 for debugging purposes.
Mario
