K32W Multilink
K32W Multilink
1,492 次查看
danieltseng
Because K32W is a new chip, it has the following problems:
1. Does the SWD interface on the K32W main board support Multilink (debug tool) download  as usual?
2. If not support  Multilink , what debug tool can be supported?
  • KW
9 回复数
1,248 次查看
danieltseng
Dear Mario,
Thank you for your response, currently resolved.
1,248 次查看
danieltseng
Hi Mario,
It's been a week since this question, is there any test result?
1,248 次查看
mario_castaneda
Hi Daniel,
Please accept my apologies for the late response.
Unfortunately, K32W is supporting the following probes:
Link2 debug probe with ARM’s CMSIS-DAP and SEGGER J-Link protocol options.
Boards user manual: https://www.nxp.com/docs/en/user-guide/UM11393%20.pdf
NXP open SDA J& link2:
   LPC-Link2 | NXP
  OpenSDA Serial and Debug Adapter | NXP
Sorry for any inconvenience that this may cause you.
Mario
1,248 次查看
mario_castaneda
Hi Daniel,
I hope you are doing great.
Sorry for my late response, We are still working on it. We are facing some delays for all of this COVID Novel.
I will get back to you as soon as possible.
Mario
1,248 次查看
danieltseng
Hi Mario,
Multilink is urgent currently , can you help me check this function first?
1,248 次查看
danieltseng
K32W multilink download
This is the result of my test, for your reference.There will be an error message。
In addition, I used Multilink to test that KW41 can be loaded normally, which means that my Multilink can work without damage.
1,248 次查看
danieltseng
In other words,
SWD interface on the Carrier Main Board support via Multilink  to download image to "LPC4322" or "K32W module chip"  ?
1,248 次查看
mario_castaneda
Hi Daniel,
I am checking the Multilink support. I will get back to you as soon as possible.
Mario
1,248 次查看
mario_castaneda
Hi Daniel,
The mainboard provides an LPC4322 with CMSIS DAP firmware. you could use this tool for debugging purposes. Also, you can use an external LPC LINK 2 for debugging purposes.
Mario
