JN516x Coordinator Forgets network nodes when it's restarded | Zigbee 3.0 | AN1229
davidashraf
Contributor V
I am working with Application Note JN_AN_1229 | Zigbee 3.0 Stack
When The coordinator node restarts it seems to forget all children nodes , so any message sent by any end device or router isn't received at the coordinator.
What should I do to keep the network formed , noting that the nodes used are sleeping end devices.
Any help ? https://community.nxp.com/community/wireless-connectivity?sr=search&searchId=072bf044-8b40-40ff-8e0a...
anca_codreanu
Did you try to set bDeleteRecords = FALSE ?
Anca-Maria Codreanu
anca_codreanu
Anca-Maria Codreanu
davidashraf
Contributor V
Thanks Anca-MariaCodreanu‌
it worked fine
