How to config JN5169 + SE2431 PA ?
lilidanny
The JN5169-001-M06-2/OM15057-1 does use JN5169 + SE2431 PA,
how can I enable the SE2431?
Is there a API or a document to describe this?
And also, if I use RFX2401C replace SE2431, the config is same?
Thanks!
estephania_mart
Could you please check this other thread? I believe this might solve your questions
Estephania
