[JN-SW-4170] Which API is for "Read Attributes" Response?
1,249件の閲覧回数
alan5_lin
Dear Sirs,
According to Chapter 2.2.1.1 of JN-UG-3103 ("Reading a Set of Attributes of a Remote Cluster"), the Destination Node will send "Read Attributes" response to the Source Node.
Where can I find the .c file which handling the response action?
Thanks!
ラベル(3)
1,151件の閲覧回数
mario_castaneda
Hi Alan,
Please look at the Application Note: JN-AN-1216 Document A.2. Message Characteristics.
The PDF explains how is the packet is formed, so you could look at the B.1. Common Commandsthat described with the message description.
Mario
6 返答(返信)
1,151件の閲覧回数
mario_castaneda
Hi Alan,
I hope you are doing great.
Please look at the APP_ZCL_cbEndpointCallback in the app_zcl_event_handler.c file.
 case E_ZCL_CBET_READ_INDIVIDUAL_ATTRIBUTE_RESPONSE:
You will find how the attribute response is handled, and the function is reading out the attribute response.
            if((psEvent->eEventType == E_ZCL_CBET_READ_INDIVIDUAL_ATTRIBUTE_RESPONSE))
                vSL_WriteMessage ( E_SL_MSG_READ_ATTRIBUTE_RESPONSE,
                                   u16Length,
                                   au8LinkTxBuffer );
Mario
1,151件の閲覧回数
alan5_lin
Dear Mario,
Thanks for your information. It seems behavior on Gateway Node.
How about on Device Node?
Where can I find the .c file which writing the attribute payload into response packet on Device Node?
Thanks!
1,151件の閲覧回数
mario_castaneda
Hi Alan,
It is the same, look at the APP_ZCL_cbEndpointCallback function. For example the JN-AN-1219 app_zcl_switch_task.c  file.
            DBG_vPrintf(TRACE_SWITCH_TASK, " Read Attrib Rsp %d %02x\n", psEvent->uMessage.sIndividualAttributeResponse.eAttributeStatus,
                *((uint8*)psEvent->uMessage.sIndividualAttributeResponse.pvAttributeData));
            break;
Mario
1,151件の閲覧回数
alan5_lin
Hi Mario,
I run ZGWUI tool to read attribute of a device node based on JN-AN-1218. Captured picture as below:
I am interesting in the packet data marked with red block.
Which .c file build up this response packet on Device Node?
How to interpret this packet byte-by-byte?
Thanks!
1,152件の閲覧回数
mario_castaneda
Hi Alan,
Mario
1,151件の閲覧回数
alan5_lin
Hi Mario,
Thanks a lot.
