Dear all,
I am confused if it is necessary to use NFC for Light-Sensor (node) to join Control-Bridge (Coordinator).
Is it possible to let Light-Sensor (node) to directly join Control-Bridge (Coordinator) after power on?
Thanks!
Solved! Go to Solution.
Hi Alan,
Sure, after pressing the Reset button, the device is scanning for any open network.
Please look at the LED Indication of Different States in the documentation.
"C:\NXP\bstudio_nxp\workspace\JN-AN-1220-Zigbee-3-0-Sensors\Doc\JN-AN-1220-ZigBee-3-0-Sensors.pdf"
-If a sensor node does not find a suitable network to join, it goes into a soft sleep after scanning all the primary and secondary channels.
Mario
Hi Alan,
Mario
Hi Mario,
Thanks for your information.
