Internal voltage reference for internal temp sensor
jc_pacheco
We want to rely on the internal voltage reference when reading the temperature sensor.
VREFH and VREFL are exposed through external pins – but these are intended for an external, high precision voltage reference.Are these connected continuously or do we have to explicitly connect them using an internal register setting?
jc_pacheco
You need to connect VREFH and VREFL to external references
jc_pacheco
