I am using the 1244 routine modification project for ZigBee3.0 authentication. How to generate OTA null firmware?
Solved! Go to Solution.
Hope you are doing well. Could you please check section B of the "JN-UG-3135-Encyption-Tool.pdf"? Path: (SDK\docs\wireless\Zigbee)
This section details how to create a NULL upgrade image for ZigBee Over-The-Air (OTA) certification.
Hope this helps.
Ricardo
Hope this helps.
Ricardo
