How can I measure FRDM-KW36 chip's currency
971件の閲覧回数
darkblue
How can I measure FRDM-KW36 chip's currency ?  I wanna know where to find the vin vout ?
933件の閲覧回数
Christine_Li
Hi, @darkblue
Thanks for choosing NXP products.
For FRDM-KW36, we have FRDM-KW36 Design Files and FRDM-KW36 Freedom Development Board User's Guide.
There are several ways to power and measure current on the FRDM-KW36 board. You can refer to this part:  3.3 Power management in FRDM-KW36 Freedom Development Board User's Guide.
for detailed power management and current measurement.
Christine.
4 返答(返信)
934件の閲覧回数
Christine_Li
Hi, @darkblue
Christine.
920件の閲覧回数
darkblue
Thx for replying. I used the digit_key_car_anchor project in kw38, just remove all peripherals . And I disabled Bluetooth scanning and broadcasting, and measured the current at 0.22mA. Is this power consumption already at its lowest, or can it be further reduced?
909件の閲覧回数
Christine_Li
Hi, @darkblue
For different power supply, it will have different results.
For KW36, we have detailed test environment setup and measurement results and in this file: Kinetis MKW36 Power Consumption Analysis.
You can reference this file for details.
Christine.
878件の閲覧回数
darkblue
I did not see any function related to can wake-up in the document
Still I enabled the enableSelfWakeup and kFLEXCAN_WakeUpInterruptEnable of the can, but after the device enters the low-power state, it cannot be awakened by can. I didn't get the kStatus_FLEXCAN_WakeUp status. How to fix it?
