Hi community, i'm using the MKW40 BLE Module and i want to know if there is any way to enable/disable the modulation, enable/disable the radio and the carrier wave without modulation.
From the KW40Zxx Reference Manual :
Chapter 44: Use of the radio will be facilitated through firmware provided by Freescale giving
customers access to all the radio features through appropriate API interfaces. As such,
detailed information on radio control registers is not provided here.
Where are those appropriate API interfaces?
Best regards.
Solved! Go to Solution.
Hi Alexis Hernandez
Please check the followings community posts:
NXP connectivity FCC/ETSI Certification Software
https://community.nxp.com/docs/DOC-332721
There is already examples codes that allows you to test radio in the connectivity software, I recommend you to check them, also please check the code to find out how radio is set.
Hope this information could help you, please let me know if you have any question about this.
Best Regards
Jorge Alcala
Hi Alexis Hernandez
Best Regards
Jorge Alcala
