What is the procedure to read data stored in the SVF321R3K1CKU2's EFuse 0x400A5460 register?
Showing results forย
Search instead forย
Did you mean:ย
jaysonbeh
Hello All,
Current I am facing the read the EFuse data from Vybrid? Does anyone have this kind of experience to retrieve the data from Vybrid. I would like to know, What is the procedure to read data stored in the SVF321R3K1CKU2's EFuse 0x400A5460 register?
karina_valencia
NXP Apps Support
NXP Apps Support
jaysonbehโ€‹ did you get previous update?
karina_valencia
NXP Apps Support
NXP Apps Support
timesyssupportโ€‹ can you help here?
timesyssupport
Senior Contributor II
I'm not having Vybrid 3xxR series board in handy but i read OTP fuse registers in the i.MX6 processor without issues. I have followed the below link for this procedure, https://boundarydevices.com/fuse-command/
If you are going to follow above link, you may need to enable the corresponding kernel driver(OTP) in your SDK, now the OTP registers are export into the userspace directory(/sys/fsl_otp), then r/w the user data into those registers(most probably 2 WORD registers in the processor).
-> Kernel driver configuration:-Kindly ensure the kernel configuration as follows:
Device Drivers -> Character devices -> [*] Freescale On-Chip OTP Memory Support.
Could you please follow the above procedure & keep update your progress with us.
Also, i came across the below link, i shared for your reference,
https://community.freescale.com/thread/311716
