T1042 Device Tree Fman RGMII-ID
5,890件の閲覧回数
stefanlange
Hello NXP team,
we have a design with a custom NXP T1042 PowerPC Module located on a custom baseboard.
Both module and baseboard are new designs.
I here have a support request regarding the Fman device tree content and syntax.
There are 5 Ethernet Interfaces in use, 3 via SGMII, 2 via RGMII.
The RGMIIs require editing the specific TX and RX RGMII delays in the phy.
I have implemented this in the device tree to my best guess (see attached).
However it seems the parameter
phy-connection-type = "rgmii-id";
is ignored during kernel boot, and thus the RGMII delay values are not set.
I also changed the parameter phy-connection-type = "sgmii"; to phy-connection-type = "aaa"; for a test
The debug print still remained at "sgmii"; it seems phy-connection-type as put in the device tree is not used at all.
See attached my .dts file and a bootlog with debug prints and comments (marked with "?").
I figure I wrote the .dts wrong in some way. I could not find a different device tree that I could use as a template.
Maybe you can shed some light.
Thank you and best regards,
Stefan
Original Attachment has been moved to: tqmt1042.dts.zip
Original Attachment has been moved to: TQMT1042_Bootlog.txt.zip
3,329件の閲覧回数
stefanlange
Hello all,
for what it's worth, I wrote a quick dirty patch for myself to solve this issue for myself.
See below.
Stefan
commit c6dffe1f34476fbb0653328521ab4124f204b007
Author: Stefan Lange <s.lange@gateware.de>
Date:   Wed Jul 13 17:37:34 2016 +0200
        Workaround to enable rgmii-id phy-connection-type with QorIQ Frame Manag
        Dirty Workaround:
        Get the true external PHY's connection type
        Workaround as FMAN overwrites the "phy-connection-type"-property
        with "rgmii" if "rgmii-id" is noted in the device tree.
        The new variable "external_phy_if" is successively used in the
        "init_phy" function further above in this .c-file.
        See also: https://community.nxp.com/thread/398029
diff --git a/arch/powerpc/boot/dts/fsl/tqmt1042.dts b/arch/powerpc/boot/dts/fsl/
index cde8d2f..e81d236 100644
--- a/arch/powerpc/boot/dts/fsl/tqmt1042.dts
+++ b/arch/powerpc/boot/dts/fsl/tqmt1042.dts
@@ -263,12 +263,14 @@
                        enet3: ethernet@e6000 {
                                phy-handle = <&phy_rgmii_0>;
+                               external-phy-connection-type = "rgmii-id";
                        /* MAC5: RGMII DP83867 */
                        enet4: ethernet@e8000 {
                                phy-handle = <&phy_rgmii_1>;
                        /* external, dedicated MDIO */
diff --git a/drivers/net/ethernet/freescale/fman/mac.c b/drivers/net/ethernet/fr
index e33d9d2..254e88c 100644
--- a/drivers/net/ethernet/freescale/fman/mac.c
+++ b/drivers/net/ethernet/freescale/fman/mac.c
@@ -67,6 +67,7 @@ struct mac_priv_s {
        struct fixed_phy_status         *fixed_link;
        u16                             speed;
        u16                             max_speed;
+       phy_interface_t                 external_phy_if;
        int (*enable)(struct fman_mac *mac_dev, enum comm_mode mode);
        int (*disable)(struct fman_mac *mac_dev, enum comm_mode mode);
@@ -476,8 +477,14 @@ static int init_phy(struct net_device *net_dev,
        struct phy_device       *phy_dev;
        struct mac_priv_s       *priv = mac_dev->priv;
-       phy_dev = of_phy_connect(net_dev, priv->phy_node, adj_lnk, 0,
+       if (priv->external_phy_if) {
+               phy_dev = of_phy_connect(net_dev, priv->phy_node, adj_lnk, 0,
+                                priv->external_phy_if);
+       else {
                                 priv->phy_if);
        if (!phy_dev) {
                netdev_err(net_dev, "Could not connect to PHY\n");
                return -ENODEV;
@@ -881,6 +888,23 @@ static int mac_probe(struct platform_device *_of_dev)
                priv->phy_if = str2phy(char_prop);
+        * Dirty Workaround:
+        * Get the true external PHY's connection type
+        * Workaround as FMAN overwrites the "phy-connection-type"-property
+        * with "rgmii" if "rgmii-id" is noted in the device tree.
+        * The new variable "external_phy_if" is successively used in the
+        * "init_phy" function further above in this .c-file.
+        * See also: https://community.nxp.com/thread/398029
+       char_prop = (const char *)of_get_property(mac_node,
+                                                 "external-phy-connection-type"
+       if (char_prop) {
+               dev_info(dev,"'external-phy-connection-type' property present in
+               dev_info(dev,"'external-phy-connection-type' set to %s \n", char
+               priv->external_phy_if = str2phy(char_prop);
        priv->speed             = phy2speed[priv->phy_if];
        priv->max_speed         = priv->speed;
        mac_dev->if_support     = DTSEC_SUPPORTED;
9 返答(返信)
3,330件の閲覧回数
stefanlange
Hello all,
See below.
Stefan
        Dirty Workaround:
        u16                             speed;
        u16                             max_speed;
+       else {
                                 priv->phy_if);
        if (!phy_dev) {
                return -ENODEV;
+       if (char_prop) {
3,329件の閲覧回数
stefanlange
Hello NXP team,
this issue is still pending.
We would be glad about a hint.
Stefan
3,329件の閲覧回数
stefanlange
Hello Avinash,
still waiting on the reply from NXP.
With some ethernet PHYs it is possible to set the RGMII delay via external strapping resistors. This might be a fallback solution in your case.
Stefan
3,329件の閲覧回数
avinashh
Hi Stefan,
I am experiencing a similar problem with my P2041 processor RGMII port, my RGMII-0 is working but not at 1Gbps and my RGMII-1 is not working at all even after implementing the delays in the PHY registers in the U-boot.
Maybe if you get a solution to your problem, you can help us also,
the link to my service request is: RGMII ETHERNET port of P2041 processor is showing alive in uboot but not pinging in kern
Avinash
3,329件の閲覧回数
bpe
Your observations are fully correct. T1042 has no internal delay on
RGMII signlas, See Note 2 to Table 48 of T1042 HW spec. You cannot
configure for it in any way. The interface type is configured at reset and cannot be
changed in software, see T1042RM, Table 4-11, fields EC1, EC2. For
this reason,  'phy-connection-type' property is there only for the sake of
completeness. The actual interface type is determined from the chip
registers that reflect RCW settings.
Platon
3,329件の閲覧回数
stefanlange
Hello Platon,
thanks for your response.
This is in a way what I had expected.
But how can I set the external(!) RGMII phy's registers?
Stefan
3,329件の閲覧回数
bpe
In general, controlling a PHY is a burden of it's driver. Consult at your PHY manufacturer/documentation and driver
maintainer/source/documentation for supported methods of setting the PHY parameters.
Typically,  MAC/PHY interface type and parameters are fully static, thus internal delays are either
pin-configured at PHY reset, if the PHY has that option, or setup once by u-Boot. Linux actually don't
have to do anything with  it.
Platon
3,329件の閲覧回数
stefanlange
Hello NXP team,
Stefan
3,329件の閲覧回数
stefanlange
Hello Platon,
we are setting the PHY's internal delays in u-boot and the interface is working correctly in u-boot.
However once the ethernet interface is initialized / used in linux, e.g. via ifconfig fm1-gb3 <ipaddr>, linux resets thePHY and the delay settings are lost.
The DP83867 driver accounts for this, it has the option of setting tx-internal-delay, rx-internal-delay via the device tree.
But: The respective routines in the driver are called only if the ethernet device tree node is set to
As the phy-connection-type attribute is ignored and hard-set to "rgmii", is there a way I can achieve the DP83867 sees phy-connection-type = "rgmii-id", or is there any other smart way to solve this?
Thanks & best regards,
Stefan
