Using T2080RDB and a fresh 1.8 SDK install.
When I rebuild u-boot, it is building 2014.07 by default.
Just used standard commands to do this build.
1. $bitbake u-boot -c cleansstate
2. $bitbake u-boot -c patch
3. Resultant source folder is build_t2080rdb/release/tmp/work/t2080rdb-fsl-linux/u-boot-qoriq/2014.07+fslgit-r0
4. $bitbake u-boot.
How do I force this to 2015.01 when setting up the build?
That is what is factory flashed to the boards I have that are using SDK 1.8. I see both 2015.01 and 2014.07 referenced in the documentation.
The simplest way concerns to use SDK 1.9. This SDK uses u-boot 2015.01.
Use also SDK 2.0. This SDK uses u-boot 2016.01.
Pavel Chubakov
