License Problem
License Problem
nikesh5383
mwcceppc.exe( processor Zen is not supported by the current set of licenses.
mwcceppc.exe( Please contact <license@freescale.com> for licensing needs
Following appears when i try to run a build. What could be the reason for such a message.
I have purchased a dongle and have the license installed.
How should i debug?
I dont use the complete Codewarrior IDE but only the compiler.
It worked well before with a floating license but now with the dongle it does not work. I even tried the evaluation version and that works absolutely fine.
Is there anything else i have to take care when using a dongle?
J2MEJediMaster
Specialist I
Try this web page. It has the latest QuickStart Guide for dongle installation and the latest drivers.
---Tom
stanish
Hi nikesh5383,
I'd suggest you to check FAQ-27403:
http://www.freescale.com/webapp/sps/utils/SingleFaq.jsp?FAQ-27403.xml
It's dedicated to CodeWarrior for ColdFire, but it's applicable to Power Architecture CodeWarrior as well.
Does the licensing issue appear also in CW IDE?
Stanish
nikesh5383
i am unable to find anny info in the FAQ that you suggested. Kindly update.
J2MEJediMaster
Specialist I
---Tom
