i.MX8MPlus data path confirm
296 次查看
Xingxing
    Can you help confirm if i.MX8MPlus support following data path? and if already have similar demo code in the SDK?
sensor(raw12, fisheye)->ISP(i.MX8, Dewarp)-> encode->USB30(uvc)
Xingxing
280 次查看
Chavira
Hi @Xingxing!
Thank you for contacting NXP Support!
You can send video through a USB bus but the speed and the resolutions could be affected in the process, I recommend using MIPI.
Best Regards!
Chavira
