MPXV7007DP Humidity Tolerance
634 次查看
dengel
I am trying to find the humidity specification for the MPXV7007DP pressure sensor.  It does not appear to be included in the datasheet.
The application wants a sensor rated for operation at 0 – 95% RH, for both the pressure column and ambient environment.
Thanks.
471 次查看
david_diaz
Hello Daniel,
Thank you for writing.
This device was not introduced for high humidity & high temperature condition and never been qualified under long term high humidity reliability test condition such as THB.
I knew this device series have been widely used for washing machine application and I expect humidity is little higher than ambient in washing machine application.
NXP never simulated customer application, so I don’t know the humidity level of washing machine.
Anyway, I would like to recommend the application note below in order to get more detailed information.
 AN3728: Media Compatibility for IPS PRT Pressure Sensors
I hope this information helps.
David
