MPR121 thermal reflow profile
1,467件の閲覧回数
jesseenjaian
I've assembled a couple of packages soaking at 180 C for one minute and reflowing at 249 C for about twenty or thirty seconds using 63/37 solder (not paste) that I tinned on the pads with a soldering iron. I calibrated the temperature with a thermocoupled thermometer, so I'm confident the applied heat is about that; I'm using a head that's about the size of the MPR121 and soaking the entire chip instead of going side-by-side. Does this sound safe for the MPR121, or am I risking damaging it?
Thanks!
Jesse Enjaian
タグ(1)
1,162件の閲覧回数
reyes
Hi Jesse Enjaian,
The Peak Package Body Temperature (PPT) for the MPR121 is 260 °C, but the maximum time at this peak temperature is 40 seconds. So yes is a risk that you are damaging the device.
You can find this information in the MPR121 Part Details.
Jose Reyes
2 返答(返信)
1,163件の閲覧回数
reyes
Hi Jesse Enjaian,
Jose Reyes
1,162件の閲覧回数
jesseenjaian
Hi Jose,
Thanks for your help. I was looking in the data sheet and reference manual, but didn't see it there.
For future reference, that was an incredibly unnecessary temperature. Using eutectic solder, I soaked at 150 C for one minute then reflowed at 189 C for twenty seconds stepping there at 2-3 C/sec. I was able to initialize and use the chip over I2C doing this.
Thanks again.
Best,
Jesse
