MMA8452 sleep current
1,886 次查看
takuya1
Hello.
I am working on a development project using MMA8452, but I am facing the problem that the sleep current of MMA8452 doesn't go down.
Automatic sleep and wake up of MMA8452 functions are set, and the CPU also transitions to sleep based on the sleep interrupt signal from MMA8452.
However, the consumption current of MMA8452 doesn't fall after sleep.
I am doing the following configuration setting on the device.
1.  standby mode setting
  readRegister(0x2A, &data);
  writeRegister(0x2A, data & ~(0x01));
2.  dynamic range setting (2G)
  readRegister(0x0E, &XYZ_DATA);
  CTRL_REG3_Data &= 0xFC;
  writeRegister(0x0E, XYZ_DATA);
3.  oversampling mode setting(SleepMode : Low Power,  ActiveMode : Low Power)
  readRegister(0x2B, &CTRL_REG2_Data);
  CTRL_REG2_Data &= 0xE4;
  CTRL_REG2_Data |= 0x1B;
  writeRegister(0x2B,CTRL_REG2_Data);
4.  automatic sleep and wake up setting
  CTRL_REG2_Data |= 0x04;
  writeRegister(0x2B, CTRL_REG2_Data);
5.  automatic sleep timer count setting (five second)
  writeRegister(0x29, 0x10);
6.  interrupt enable setting  (motion, automatic sleep and wake up enable)
  writeRegister(0x2D, 0x84);
7.  configuration setting (set auto sleep, wake up to INT1)
  writeRegister(0x2E, 0x80);
8.  wake up control setting (motion)
  writeRegister(0x2C, 0x08);
9.  sample rate setting (sleep : 12.5Hz,  wake : 12.5Hz)
  readRegister(0x2A, &CTRL_REG1_Data);
  CTRL_REG1_Data &= 0x07;
  CTRL_REG1_Data |= 0x68;
  writeRegister(0x2A,CTRL_REG1_Data);
10.  motion detection setting
  writeRegister(0x15, 0xD8);
11.  motion detection threshold setting ( switchable)
  writeRegister(0x17, 0x01);
  writeRegister(0x17, 0x02);
  writeRegister(0x17, 0x03);
12.  device counter setting (300ms/80ms=4)
  writeRegister(0x18, 0x04);
13.  active mode setting
  writeRegister(0x2A, data | 0x01);
Is there a cause for the sleep current not to fall in the above settings?
The board current at sleep is 235uA, but if you remove the MMA8452 from the board and put the CPU to sleep, the board current will drop to 5uA.
Takuya
标签 (1)
1 回复
1,701 次查看
TomasVaverka
Hello Takuya-san,
I do not have enough time right now to try to reproduce your settings, but there is a good example illustrating the use of auto-wake/sleep mode available at:
https://community.nxp.com/docs/DOC-332453
Eventually you can also take a closer look at my example code at:
https://community.nxp.com/thread/318705
Hope it helps!
Tomas
PS: If this answer helps to solve your question, please mark it as "Correct" or “Helpful”. Thank you.
%3CLINGO-SUB%20id%3D%22lingo-sub-963025%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EMMA8452%20%E4%BC%91%E7%9C%A0%E7%94%B5%E6%B5%81%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-963025%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E6%82%A8%E5%A5%BD%E3%80%82%3C%2FP%3E%3CP%3E%E6%88%91%E6%AD%A3%E5%9C%A8%E5%81%9A%E4%B8%80%E4%B8%AA%E4%BD%BF%E7%94%A8%20MMA8452%20%E7%9A%84%E5%BC%80%E5%8F%91%E9%A1%B9%E7%9B%AE%EF%BC%8C%E4%BD%86%E6%88%91%E9%81%87%E5%88%B0%E4%BA%86%E4%B8%80%E4%B8%AA%E9%97%AE%E9%A2%98%EF%BC%8C%E5%8D%B3%20MMA8452%20%E7%9A%84%E4%BC%91%E7%9C%A0%E7%94%B5%E6%B5%81%E6%B2%A1%E6%9C%89%E4%B8%8B%E9%99%8D%E3%80%82%3C%2FP%3E%3CP%3E%E8%AE%BE%E7%BD%AE%E4%BA%86%20MMA8452%20%E7%9A%84%E8%87%AA%E5%8A%A8%E4%BC%91%E7%9C%A0%E5%92%8C%E5%94%A4%E9%86%92%E5%8A%9F%E8%83%BD%EF%BC%8CCPU%20%E4%B9%9F%E4%BC%9A%E6%A0%B9%E6%8D%AE%E6%9D%A5%E8%87%AA%20MMA8452%20%E7%9A%84%E4%BC%91%E7%9C%A0%E4%B8%AD%E6%96%AD%E4%BF%A1%E5%8F%B7%E8%BF%9B%E5%85%A5%E4%BC%91%E7%9C%A0%E7%8A%B6%E6%80%81%E3%80%82%3C%2FP%3E%3CP%3E%E4%B8%8D%E8%BF%87%EF%BC%8CMMA8452%20%E7%9A%84%E6%B6%88%E8%80%97%E7%94%B5%E6%B5%81%E5%9C%A8%E7%9D%A1%E7%9C%A0%E5%90%8E%E4%B8%8D%E4%BC%9A%E4%B8%8B%E9%99%8D%E3%80%82%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22display%3A%20inline%20!important%3B%20float%3A%20none%3B%20background-color%3A%20transparent%3B%20color%3A%20%2351626f%3B%20font-family%3A%20arial%2Chelvetica%2C'helvetica%20neue'%2Cverdana%2Csans-serif%3B%20font-size%3A%2015px%3B%20font-style%3A%20normal%3B%20font-variant%3A%20normal%3B%20font-weight%3A%20400%3B%20letter-spacing%3A%20normal%3B%20orphans%3A%202%3B%20text-align%3A%20left%3B%20text-decoration%3A%20none%3B%20text-indent%3A%200px%3B%20text-transform%3A%20none%3B%20-webkit-text-stroke-width%3A%200px%3B%20white-space%3A%20normal%3B%20word-spacing%3A%200px%3B%20word-wrap%3A%20break-word%3B%22%3E%E6%88%91%E6%AD%A3%E5%9C%A8%E8%AE%BE%E5%A4%87%E4%B8%8A%E8%BF%9B%E8%A1%8C%E4%BB%A5%E4%B8%8B%E9%85%8D%E7%BD%AE%E8%AE%BE%E7%BD%AE%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22display%3A%20inline%20!important%3B%20float%3A%20none%3B%20background-color%3A%20transparent%3B%20color%3A%20%2351626f%3B%20font-family%3A%20arial%2Chelvetica%2C'helvetica%20neue'%2Cverdana%2Csans-serif%3B%20font-size%3A%2015px%3B%20font-style%3A%20normal%3B%20font-variant%3A%20normal%3B%20font-weight%3A%20400%3B%20letter-spacing%3A%20normal%3B%20orphans%3A%202%3B%20text-align%3A%20left%3B%20text-decoration%3A%20none%3B%20text-indent%3A%200px%3B%20text-transform%3A%20none%3B%20-webkit-text-stroke-width%3A%200px%3B%20white-space%3A%20normal%3B%20word-spacing%3A%200px%3B%20word-wrap%3A%20break-word%3B%22%3E1.%20%E5%BE%85%E6%9C%BA%E6%A8%A1%E5%BC%8F%E8%AE%BE%E7%BD%AE%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22display%3A%20inline%20!important%3B%20float%3A%20none%3B%20background-color%3A%20transparent%3B%20color%3A%20%2351626f%3B%20font-family%3A%20arial%2Chelvetica%2C'helvetica%20neue'%2Cverdana%2Csans-serif%3B%20font-size%3A%2015px%3B%20font-style%3A%20normal%3B%20font-variant%3A%20normal%3B%20font-weight%3A%20400%3B%20letter-spacing%3A%20normal%3B%20orphans%3A%202%3B%20text-align%3A%20left%3B%20text-decoration%3A%20none%3B%20text-indent%3A%200px%3B%20text-transform%3A%20none%3B%20-webkit-text-stroke-width%3A%200px%3B%20white-space%3A%20normal%3B%20word-spacing%3A%200px%3B%20word-wrap%3A%20break-word%3B%22%3EreadRegister(0x2A%2C%26amp%3Bdata)%3B%3CBR%20%2F%3EwriteRegister(0x2A%2C%20data%26amp%3B%20~(0x01))%EF%BC%9B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22display%3A%20inline%20!important%3B%20float%3A%20none%3B%20background-color%3A%20transparent%3B%20color%3A%20%2351626f%3B%20font-family%3A%20arial%2Chelvetica%2C'helvetica%20neue'%2Cverdana%2Csans-serif%3B%20font-size%3A%2015px%3B%20font-style%3A%20normal%3B%20font-variant%3A%20normal%3B%20font-weight%3A%20400%3B%20letter-spacing%3A%20normal%3B%20orphans%3A%202%3B%20text-align%3A%20left%3B%20text-decoration%3A%20none%3B%20text-indent%3A%200px%3B%20text-transform%3A%20none%3B%20-webkit-text-stroke-width%3A%200px%3B%20white-space%3A%20normal%3B%20word-spacing%3A%200px%3B%20word-wrap%3A%20break-word%3B%22%3E2.%20%E5%8A%A8%E6%80%81%E8%8C%83%E5%9B%B4%E8%AE%BE%E7%BD%AE%20(2G)%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22display%3A%20inline%20!important%3B%20float%3A%20none%3B%20background-color%3A%20transparent%3B%20color%3A%20%2351626f%3B%20font-family%3A%20arial%2Chelvetica%2C'helvetica%20neue'%2Cverdana%2Csans-serif%3B%20font-size%3A%2015px%3B%20font-style%3A%20normal%3B%20font-variant%3A%20normal%3B%20font-weight%3A%20400%3B%20letter-spacing%3A%20normal%3B%20orphans%3A%202%3B%20text-align%3A%20left%3B%20text-decoration%3A%20none%3B%20text-indent%3A%200px%3B%20text-transform%3A%20none%3B%20-webkit-text-stroke-width%3A%200px%3B%20white-space%3A%20normal%3B%20word-spacing%3A%200px%3B%20word-wrap%3A%20break-word%3B%22%3EreadRegister(0x0E%2C%26amp%3BXYZ_DATA)%3B%3CBR%20%2F%3ECTRL_REG3_Data%26amp%3B%3D%200xFC%3B%3CBR%20%2F%3EwriteRegister(0x0E%2C%20XYZ_DATA)%EF%BC%9B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22display%3A%20inline%20!important%3B%20float%3A%20none%3B%20background-color%3A%20transparent%3B%20color%3A%20%2351626f%3B%20font-family%3A%20arial%2Chelvetica%2C'helvetica%20neue'%2Cverdana%2Csans-serif%3B%20font-size%3A%2015px%3B%20font-style%3A%20normal%3B%20font-variant%3A%20normal%3B%20font-weight%3A%20400%3B%20letter-spacing%3A%20normal%3B%20orphans%3A%202%3B%20text-align%3A%20left%3B%20text-decoration%3A%20none%3B%20text-indent%3A%200px%3B%20text-transform%3A%20none%3B%20-webkit-text-stroke-width%3A%200px%3B%20white-space%3A%20normal%3B%20word-spacing%3A%200px%3B%20word-wrap%3A%20break-word%3B%22%3E3.%20%E8%B6%85%E9%87%87%E6%A0%B7%E6%A8%A1%E5%BC%8F%E8%AE%BE%E7%BD%AE%EF%BC%88%E7%9D%A1%E7%9C%A0%E6%A8%A1%E5%BC%8F%EF%BC%9A%E4%BD%8E%E5%8A%9F%E8%80%97%EF%BC%8C%E6%B4%BB%E5%8A%A8%E6%A8%A1%E5%BC%8F%EF%BC%9A%E4%BD%8E%E5%8A%9F%E8%80%97%EF%BC%89%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22display%3A%20inline%20!important%3B%20float%3A%20none%3B%20background-color%3A%20transparent%3B%20color%3A%20%2351626f%3B%20font-family%3A%20arial%2Chelvetica%2C'helvetica%20neue'%2Cverdana%2Csans-serif%3B%20font-size%3A%2015px%3B%20font-style%3A%20normal%3B%20font-variant%3A%20normal%3B%20font-weight%3A%20400%3B%20letter-spacing%3A%20normal%3B%20orphans%3A%202%3B%20text-align%3A%20left%3B%20text-decoration%3A%20none%3B%20text-indent%3A%200px%3B%20text-transform%3A%20none%3B%20-webkit-text-stroke-width%3A%200px%3B%20white-space%3A%20normal%3B%20word-spacing%3A%200px%3B%20word-wrap%3A%20break-word%3B%22%3EreadRegister(0x2B%2C%26amp%3BCTRL_REG2_Data)%3B%3CBR%20%2F%3ECTRL_REG2_Data%26amp%3B%3D%200xE4%3B%3CBR%20%2F%3ECTRL_REG2_Data%20%7C%3D%200x1B%3B%3CBR%20%2F%3EwriteRegister(0x2B%2CCTRL_REG2_Data)%EF%BC%9B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22display%3A%20inline%20!important%3B%20float%3A%20none%3B%20background-color%3A%20transparent%3B%20color%3A%20%2351626f%3B%20font-family%3A%20arial%2Chelvetica%2C'helvetica%20neue'%2Cverdana%2Csans-serif%3B%20font-size%3A%2015px%3B%20font-style%3A%20normal%3B%20font-variant%3A%20normal%3B%20font-weight%3A%20400%3B%20letter-spacing%3A%20normal%3B%20orphans%3A%202%3B%20text-align%3A%20left%3B%20text-decoration%3A%20none%3B%20text-indent%3A%200px%3B%20text-transform%3A%20none%3B%20-webkit-text-stroke-width%3A%200px%3B%20white-space%3A%20normal%3B%20word-spacing%3A%200px%3B%20word-wrap%3A%20break-word%3B%22%3E4.%20%E8%87%AA%E5%8A%A8%E7%9D%A1%E7%9C%A0%E5%92%8C%E5%94%A4%E9%86%92%E8%AE%BE%E7%BD%AE%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22display%3A%20inline%20!important%3B%20float%3A%20none%3B%20background-color%3A%20transparent%3B%20color%3A%20%2351626f%3B%20font-family%3A%20arial%2Chelvetica%2C'helvetica%20neue'%2Cverdana%2Csans-serif%3B%20font-size%3A%2015px%3B%20font-style%3A%20normal%3B%20font-variant%3A%20normal%3B%20font-weight%3A%20400%3B%20letter-spacing%3A%20normal%3B%20orphans%3A%202%3B%20text-align%3A%20left%3B%20text-decoration%3A%20none%3B%20text-indent%3A%200px%3B%20text-transform%3A%20none%3B%20-webkit-text-stroke-width%3A%200px%3B%20white-space%3A%20normal%3B%20word-spacing%3A%200px%3B%20word-wrap%3A%20break-word%3B%22%3EreadRegister(0x2B%2C%26amp%3BCTRL_REG2_Data)%3B%3CBR%20%2F%3ECTRL_REG2_Data%20%7C%3D%200x04%3B%3CBR%20%2F%3EwriteRegister(0x2B%2C%20CTRL_REG2_Data)%EF%BC%9B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22display%3A%20inline%20!important%3B%20float%3A%20none%3B%20background-color%3A%20transparent%3B%20color%3A%20%2351626f%3B%20font-family%3A%20arial%2Chelvetica%2C'helvetica%20neue'%2Cverdana%2Csans-serif%3B%20font-size%3A%2015px%3B%20font-style%3A%20normal%3B%20font-variant%3A%20normal%3B%20font-weight%3A%20400%3B%20letter-spacing%3A%20normal%3B%20orphans%3A%202%3B%20text-align%3A%20left%3B%20text-decoration%3A%20none%3B%20text-indent%3A%200px%3B%20text-transform%3A%20none%3B%20-webkit-text-stroke-width%3A%200px%3B%20white-space%3A%20normal%3B%20word-spacing%3A%200px%3B%20word-wrap%3A%20break-word%3B%22%3E5.%20%E8%87%AA%E5%8A%A8%E7%9D%A1%E7%9C%A0%E8%AE%A1%E6%97%B6%E5%99%A8%E8%AE%A1%E6%95%B0%E8%AE%BE%E7%BD%AE%EF%BC%88%E4%BA%94%E7%A7%92%EF%BC%89%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22display%3A%20inline%20!important%3B%20float%3A%20none%3B%20background-color%3A%20transparent%3B%20color%3A%20%2351626f%3B%20font-family%3A%20arial%2Chelvetica%2C'helvetica%20neue'%2Cverdana%2Csans-serif%3B%20font-size%3A%2015px%3B%20font-style%3A%20normal%3B%20font-variant%3A%20normal%3B%20font-weight%3A%20400%3B%20letter-spacing%3A%20normal%3B%20orphans%3A%202%3B%20text-align%3A%20left%3B%20text-decoration%3A%20none%3B%20text-indent%3A%200px%3B%20text-transform%3A%20none%3B%20-webkit-text-stroke-width%3A%200px%3B%20white-space%3A%20normal%3B%20word-spacing%3A%200px%3B%20word-wrap%3A%20break-word%3B%22%3E%E5%86%99%E5%85%A5%E5%AF%84%E5%AD%98%E5%99%A8%EF%BC%880x29%2C%200x10%EF%BC%89%EF%BC%9B%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E6.%20%E4%B8%AD%E6%96%AD%E5%90%AF%E7%94%A8%E8%AE%BE%E7%BD%AE%EF%BC%88%E8%BF%90%E5%8A%A8%E3%80%81%E8%87%AA%E5%8A%A8%E4%BC%91%E7%9C%A0%E5%92%8C%E5%94%A4%E9%86%92%E5%90%AF%E7%94%A8%EF%BC%89%3C%2FP%3E%3CP%3E%E5%86%99%E5%85%A5%E5%AF%84%E5%AD%98%E5%99%A8%EF%BC%880x2D%2C%200x84%EF%BC%89%EF%BC%9B%3C%2FP%3E%3CP%3E7.%20%E9%85%8D%E7%BD%AE%E8%AE%BE%E7%BD%AE%EF%BC%88%E8%AE%BE%E7%BD%AE%E8%87%AA%E5%8A%A8%E4%BC%91%E7%9C%A0%EF%BC%8C%E5%94%A4%E9%86%92%E8%87%B3%20INT1%EF%BC%89%3C%2FP%3E%3CP%3E%E5%86%99%E5%85%A5%E5%AF%84%E5%AD%98%E5%99%A8%EF%BC%880x2E%2C%200x80%EF%BC%89%EF%BC%9B%3C%2FP%3E%3CP%3E8.%20%E5%94%A4%E9%86%92%E6%8E%A7%E5%88%B6%E8%AE%BE%E7%BD%AE%EF%BC%88%E5%8A%A8%E4%BD%9C%EF%BC%89%3C%2FP%3E%3CP%3E%E5%86%99%E5%85%A5%E5%AF%84%E5%AD%98%E5%99%A8%EF%BC%880x2C%2C%200x08%EF%BC%89%EF%BC%9B%3C%2FP%3E%3CP%3E9.%20%E9%87%87%E6%A0%B7%E7%8E%87%E8%AE%BE%E7%BD%AE%EF%BC%88%E7%9D%A1%E7%9C%A0%EF%BC%9A12.5Hz%EF%BC%8C%E5%94%A4%E9%86%92%EF%BC%9A12.5Hz%EF%BC%89%3C%2FP%3E%3CP%3EreadRegister(0x2A%2C%26amp%3BCTRL_REG1_Data)%3B%3CBR%20%2F%3ECTRL_REG1_Data%26amp%3B%3D%200x07%3B%3CBR%20%2F%3ECTRL_REG1_Data%20%7C%3D%200x68%3B%3CBR%20%2F%3EwriteRegister(0x2A%2CCTRL_REG1_Data)%EF%BC%9B%3C%2FP%3E%3CP%3E10.%20%E7%A7%BB%E5%8A%A8%E4%BE%A6%E6%B5%8B%E8%AE%BE%E7%BD%AE%3C%2FP%3E%3CP%3E%E5%86%99%E5%85%A5%E5%AF%84%E5%AD%98%E5%99%A8%EF%BC%880x15%2C%200xD8%EF%BC%89%EF%BC%9B%3C%2FP%3E%3CP%3E11.%20%E7%A7%BB%E5%8A%A8%E4%BE%A6%E6%B5%8B%E9%98%88%E5%80%BC%E8%AE%BE%E7%BD%AE%EF%BC%88%E5%8F%AF%E5%88%87%E6%8D%A2%EF%BC%89%3C%2FP%3E%3CP%3EwriteRegister(0x17%2C%200x01)%3B%3CBR%20%2F%3EwriteRegister(0x17%2C%200x02)%3B%3CBR%20%2F%3EwriteRegister(0x17%2C%200x03)%EF%BC%9B%3C%2FP%3E%3CP%3E12.%20%E8%AE%BE%E5%A4%87%E8%AE%A1%E6%95%B0%E5%99%A8%E8%AE%BE%E7%BD%AE%20(300ms%2F80ms%3D4)%3C%2FP%3E%3CP%3E%E5%86%99%E5%85%A5%E5%AF%84%E5%AD%98%E5%99%A8%EF%BC%880x18%2C%200x04%EF%BC%89%EF%BC%9B%3C%2FP%3E%3CP%3E13.%20%E8%BF%90%E8%A1%8C%E6%A8%A1%E5%BC%8F%E8%AE%BE%E7%BD%AE%3C%2FP%3E%3CP%3EreadRegister(0x2A%2C%26amp%3Bdata)%3B%3CBR%20%2F%3EwriteRegister(0x2A%2C%20data%20%7C%200x01)%EF%BC%9B%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E5%9C%A8%E4%B8%8A%E8%BF%B0%E8%AE%BE%E7%BD%AE%E4%B8%AD%EF%BC%8C%E7%9D%A1%E7%9C%A0%E7%94%B5%E6%B5%81%E6%B2%A1%E6%9C%89%E4%B8%8B%E9%99%8D%E7%9A%84%E5%8E%9F%E5%9B%A0%E6%98%AF%E4%BB%80%E4%B9%88%EF%BC%9F%3C%2FP%3E%3CP%3E%E6%9D%BF%E5%9C%A8%E4%BC%91%E7%9C%A0%E7%8A%B6%E6%80%81%E4%B8%8B%E7%9A%84%E7%94%B5%E6%B5%81%E4%B8%BA%20235uA%EF%BC%8C%E4%BD%86%E5%A6%82%E6%9E%9C%E6%82%A8%E5%B0%86%20MMA8452%20%E4%BB%8E%E6%9D%BF%E4%B8%8A%E6%8B%86%E4%B8%8B%EF%BC%8C%E8%AE%A9%20CPU%20%E8%BF%9B%E5%85%A5%E7%9D%A1%E7%9C%A0%E7%8A%B6%E6%80%81%EF%BC%8C%E6%9D%BF%E7%94%B5%E6%B5%81%E5%B0%86%E9%99%8D%E8%87%B3%205uA%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%AD%A4%E8%87%B4%EF%BC%8C%3C%2FP%3E%3CP%3ETakuya%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-963025%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3E%E5%8A%A0%E9%80%9F%E5%BA%A6%E4%BC%A0%E6%84%9F%E5%99%A8%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-963026%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20MMA8452%20sleep%20current%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-963026%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E6%8B%93%E4%B9%9F%E5%85%88%E7%94%9F%E5%A5%BD%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%88%91%E7%8E%B0%E5%9C%A8%E6%B2%A1%E6%9C%89%E8%B6%B3%E5%A4%9F%E7%9A%84%E6%97%B6%E9%97%B4%E5%B0%9D%E8%AF%95%E9%87%8D%E7%8E%B0%E6%82%A8%E7%9A%84%E8%AE%BE%E7%BD%AE%EF%BC%8C%E4%BD%86%E5%9C%A8%E4%BB%A5%E4%B8%8B%E7%BD%91%E7%AB%99%E4%B8%8A%E6%9C%89%E4%B8%80%E4%B8%AA%E5%BE%88%E5%A5%BD%E7%9A%84%E4%BE%8B%E5%AD%90%E5%8F%AF%E4%BB%A5%E8%AF%B4%E6%98%8E%E8%87%AA%E5%8A%A8%E5%94%A4%E9%86%92%2F%E4%BC%91%E7%9C%A0%E6%A8%A1%E5%BC%8F%E7%9A%84%E4%BD%BF%E7%94%A8%EF%BC%9A%3C%2FP%3E%3CP%3E%3CA%20_jive_internal%3D%22true%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fdocs%2FDOC-332453%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fcommunity.nxp.com%2Fdocs%2FDOC-332453%3C%2FA%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%9C%80%E5%90%8E%EF%BC%8C%E6%82%A8%E8%BF%98%E5%8F%AF%E4%BB%A5%E9%80%9A%E8%BF%87%E4%BB%A5%E4%B8%8B%E7%BD%91%E5%9D%80%E4%BB%94%E7%BB%86%E6%9F%A5%E7%9C%8B%E6%88%91%E7%9A%84%E7%A4%BA%E4%BE%8B%E4%BB%A3%E7%A0%81%EF%BC%9A%3C%2FP%3E%3CP%3E%3CA%20_jive_internal%3D%22true%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fthread%2F318705%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fcommunity.nxp.com%2Fthread%2F318705%3C%2FA%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E5%B8%8C%E6%9C%9B%E5%AF%B9%E6%82%A8%E6%9C%89%E5%B8%AE%E5%8A%A9%EF%BC%81%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E9%A1%BA%E7%A5%9D%E5%95%86%E7%A5%BA%EF%BC%81%3C%2FP%3E%3CP%3E%E6%89%98%E9%A9%AC%E6%96%AF%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CEM%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2012px%3B%22%3EPS%EF%BC%9A%E5%A6%82%E6%9E%9C%E6%AD%A4%E7%AD%94%E6%A1%88%E6%9C%89%E5%8A%A9%E4%BA%8E%E8%A7%A3%E5%86%B3%E6%82%A8%E7%9A%84%E9%97%AE%E9%A2%98%EF%BC%8C%E8%AF%B7%E6%A0%87%E8%AE%B0%E4%B8%BA%22%E6%AD%A3%E7%A1%AE%22%20%E6%88%96%20%22%E6%9C%89%E5%B8%AE%E5%8A%A9%22%E3%80%82%E8%B0%A2%E8%B0%A2%E3%80%82%3C%2FEM%3E%3C%2FP%3E%3CDIV%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2014px%3B%22%3E%3C%2FDIV%3E%3CDIV%20class%3D%22%22%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2014px%3B%20margin%3A%2020px%200px%200px%3B%22%3E%3CDIV%20class%3D%22%22%20data-comment-id%3D%221182634%22%20style%3D%22color%3A%20%23646464%3B%20border%3A%20none%3B%20font-weight%3A%20inherit%3B%20font-size%3A%200.8571rem%3B%22%3E%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FLINGO-BODY%3E
