FXLS8967AF - read FIFO?
1,056 次查看
andrewneil
I don't find the datasheet at all clear on how to read out the values from the FIFO.
Is it necessary to repeatedly read the individual triplets
for each triplet
   sensor_comm_read( handle, FXLS896xAF_BUF_X_LSB, 6, data );
Or will a single burst read get all the triplets
sensor_comm_read( handle, FXLS896xAF_BUF_X_LSB, number_of_triplets*6, data );
ie, does the auto-increment loop-back from BUF_Z_MSB to BUF_X_LSB so long as there is more data in the FIFO?
7 回复数
1,040 次查看
diazmarin09
Hello andrewneil,
I hope all is great with you. Thank you for using the NXP communities.
The byte order of the output data is programmable via SENS_CONFIG2[LE_BE], and defaults to little-endian mode.
If SENS_CONFIG2[F_READ] = 1, the auto increment mechanism skips over the MSB registers. This operation shortens the output data size from 6 bytes to 3 bytes per XYZ sample.
I do recommend downloading the driver example from the link below and using it as a reference for your design.
Sensor Drivers for NXP Sensors
I hope this information helps.
David
1,028 次查看
andrewneil
I'm sorry, that doesn't answer the question at all.
The question is, to read the entire FIFO:
  1. can I read the entire FIFO with a single burst read, or
  2. must I do multiple burst reads - one for each (X,Y,Z) triplet ?
In other words, what happens in a burst read after reading BUF_Z_MSB (0x11):
  • does it "loop-back" to BUF_X_LSB (0x0C), or
  • does it carry on to PROD_REV (0x12) ?
I have downloaded the drivers - they do not illustrate this.
997 次查看
diazmarin09
Hello andrewneil,
Please accept my apologies for the misunderstanding.
You are correct, should perform multiple burst reading procedures to read the entire buffer.
David
958 次查看
andrewneil
@diazmarin09 - should perform multiple burst reading procedures
Really?
As already noted, that Table 20 in the datasheet is very confusing:
https://community.nxp.com/t5/Sensors/FXLS8967AF-Confused-by-quot-Auto-increment-Address-quot/m-p/178...
But I think I've now managed to figure it out:
So a Normal (F_READ=0) burst read of 13 bytes starting at 0x0B should get:
  1. BUF_STATUS (0Bh)
  2. BUF_X_LSB  (0Ch)
  3. BUF_X_MSB  (0Dh)
  4. BUF_Y_LSB  (0Eh)
  5. BUF_Y_MSB  (0Fh)
  6. BUF_Z_LSB  (10h)
  7. BUF_Z_MSB  (11h)
  8. BUF_X_LSB  (0Ch)
  9. BUF_X_MSB  (0Dh)
  10. BUF_Y_LSB  (0Eh)
  11. BUF_Y_MSB  (0Fh)
  12. BUF_Z_LSB  (10h)
  13. BUF_Z_MSB  (11h)
Yes ?
Or have I still not understood Table 20 ?
948 次查看
diazmarin09
Hello andrewneil,
I know that Table 20 is indeed confusing, but your understanding is correct. I mean, that is the expected registers sequence with the auto-increment feature and F_READ=0.
David
944 次查看
andrewneil
Good.
So it should require just one burst to read the entire FIFO?
BUF_STATUS[BUF_CNT]  indicates the number of triplets required, so the total burst length required would be six times the BUF_STATUS[BUF_CNT] value ?
It certainly is!
I will update the other thread on that topic:
933 次查看
diazmarin09
Hello andrewneil,
BUF_STATUS[BUF_CNT]  indicates the number of triplets required, so the total burst length required would be six times the BUF_STATUS[BUF_CNT] value?
You are correct, my apologies for the confusion. I do appreciate your efforts.
David
