Followed the instruction provided in the tutorial.
it fails with
App :INFO :If you want to over-ride the selection, use ENV=EX_SSS_BOOT_SSS_PORT or pass in command line arguments.
ssse-flw: Version: 1.0.5
ssse-flw: EmbSe_Init(): Exit
ssse-flw: EmbSe_Rand invoked requesting 16 random bytes
ssse-flw: EmbSe_Rand invoked requesting 32 random bytes
ssse-flw: EmbSe_Compute_Key invoked (ecdh)
ssse-dbg: Requested secret = 32
ssse-dbg: ** nid = 415 **
ssse-flw: No matching key in SE. Invoking OpenSSL API: ECDH_compute_key.
ssse-flw: ECDH_compute_key by OpenSSL PASS
ssse-dbg: Using keyId=0x00223344
ssse-dbg: shaAlgo: 771
ssse-flw: SSS based sign (keyId=0x00223344, dgstLen=32)
ssse-flw: SSS based sign called successfully (sigDERLen=72)
ssse-flw: EmbSe_ECDSA_Do_Sign success.
Failed to connect, return code -1
any idea what could be the cause, not much info for me to trouble shoot on this. May I know is the error is on A71CH or connection to azure?
Hi @nd88 ,
Would you please specify the MW version?
Thanks for your patience!
Kan
@Kan_Li I am using the MW you suggested in one of my previous post.
https://www.nxp.com/webapp/Download?colCode=SE-PLUG-TRUST-MW
and I am using MCIMX6UL-EVKB-ND with A71CH
Hi @nd88 ,
Thanks for the clarification!
Have you followed the steps listed in the docs along with the MW?
For example,
and have you ever tried other demos such as "ex_ecc"? Did it also run into issue like this?
Kan
