How to avoid jumping to HardFault_Handler in EIM
590件の閲覧回数
Sylvia_jiang
Hi Community,
     I am trying to debug FCCU EIM  as below:
debug condition:
1) software is S32DS 3.5,
2) debugger is Multilink,
3) EVB is Q172,
4) SPD configurations keep defaults except that NMI Notification API is UserAlarmHandler (define as above),
5) FCCU 0 Interrupt and FCCU 1 Interrupt is enabled, FCCU_0_ISR is FCCU_ALARM_ISR, FCCU_1_ISR is FCCU_TIMEOUT_ISR,
My Question is:
1) eMcem_Init() return is E_NOT_OK because register NCF_S0(address:4038_4080h) is always 1 which indicates NCF0 faults occured, and this fault cannot be clear by writing 1, what shall I do for  successful eMcem_Init? or eMcem_Init doesn't support multilink debugging?
2)eMcem_Eim_SetupInjectionChannel() step into highligh code as below ,
 and then jump to HardFault_Handler. What shall I do for successful performing this function ?
3) Is there any S32K3XX example about EIM/ERM including configurations and some codes?
タグ(3)
0 返答(返信)
