Can you please provide FIT value for the following item and its derating formula?
for your information,
TJA1044GT/3 failure rate is evaluated per IEC/TR62380.
The values are
lambda_die=5.7FIT
lambda_pck=4.7FIT
lambda_eos=3.5FIT
This source is conservative.
As a second information, It is to be noted the evaluated failure rate is 1FIT based on field return.
Our suggestion is to consider for raw failure rate the conservative value from IEC/TR62380 for your analysis.
thank you
best regards
