hi,I want to know whether the internal real-time clock can run under VLPS mode?
First, I checked the s32-rm (rev4) data
1. on P1367
Power, clocking, and reset
The RTC is an always powered-block that remains active in all low power modes
That is, it works in all low power modes
2. on P955
In powermanage, RTC in VLPS mode is off state,off Module and clock sources are disabled, and off represents the block clock source prohibition
Therefore, I don't know whether RTC can work in VLPS mode, so I have done relevant experiments to prove whether VLPS continue to time from run-> lvps-> RUN ,
Whether to continue timing in mode on vlps
I have shown that both external crystal oscillations and internal real-time clocks within the internal clock source are valid
thanks for your reply,I wonder what that means about Async operation ,
Please refer to Table 7-8, S32K1xx_RM_r7.
All the other clock sources (LPOCLKS[RTCCLKSEL]) are gated off in VLPS.
