problem about HardFault_Handler
2,193 次查看
_simple_
I use CAN0 recive data, but sometime it will run HardFault_Handler,why?
THANKS!
6 回复数
1,911 次查看
robertboys
Hello
This might be helpful:   http://www.keil.com/appnotes/files/apnt209.pdf
Bob
1,911 次查看
_simple_
Thank you!
1,911 次查看
danielmartynek
You can check S32_SCB->CFSR register to see what type of exception it is.
Detailed description of this register can be found in Cortex-M4 Devices Generic User Guide (chapter 4.3.10).
Also, you can extend the HardFault_Handler function to get stack frame.
Program counter (pc) holds address of the instruction that has caused the exception.
void HardFault_Handler(void)
// LR provides information of the return stack PSP/MSP
asm("MOVS R0, #4");
asm("MOV R1, LR");
asm("TST R0, R1");
asm("BEQ _MSP");
asm("MRS R0, PSP");
asm("B getStackFrame");
asm("_MSP:");
asm("MRS R0, MSP");
void getStackFrame(uint32_t *stackFrame)
r0  = stackFrame[0];
r1  = stackFrame[1];
r2  = stackFrame[2];
r3  = stackFrame[3];
r12 = stackFrame[4];
lr  = stackFrame[5];
pc  = stackFrame[6];
psr = stackFrame[7];
asm("BKPT");
1,911 次查看
_simple_
I add these code into HardFault_Handler,but the translater report follow error:
Multiple markers at this line
- Symbol 'r0' could not be resolved
- 'r0' undeclared (first use in this function)
1,911 次查看
danielmartynek
Symbols r0, r1 ... are variables and must be declared: uint32_t r0;
Also, the function getStackFrame should have a prototype.
1,911 次查看
_simple_
thank you!
