Hi nxp community,
I want to use the printf funcrtion in S32S.3.5 but i con't see results "hello world" at the console or terminal. so far i can not see results whenever i run the code. is there a special configuration required to use this function ? i am using the GBD SEGGER J-Link Debugging line and SWD.
#S32DS #printf @jiri_kral
解決済! 解決策の投稿を見る。
easiest way is enable semihosting console. Anyway, what's your target device and debugger?
@jiri_kral sorry for so many questions, I'm really new to the S32D IDE.
I want to try using the UART port instead since for the printf, because I want to send messages over UART for my project. I have a USB serial on my board, I want to try the [S32K1 AUTOSAR 4.4 RTD 1.0.1 D2202 Example Projects] example name is [Uart_Example_S32K144]. But so far I have some issues with the Port_ci_Port_lp_Cfg files. I can't change the PIN based on my board. I want to use Pin PTC6 as RX and Pin PTC7 as Tx. But I'm having problems as shown below..How can I change the pins? or what am I missing?
Which of the following headers can I use to configure the Pins
you need to implement the _write function which is called by printf at the end for example like this:
int _write(int file, char *ptr, int len)
int i;
file = file;
for (i = 0; i < len; i++)
UART_PutByte(*ptr++);
return len;
Instead UART_PutByte you can use something like UART_Send(buffer,len), but the implementation is up to you. You can re-use uart send code from an existing RTD example.
Anyway, the STD C printf is pretty complex and even for "hello word" message it uses a lot of instructions. In my opinion - If you like to send some simple status/log messages it is better implement your own print which directly sends buffer into uart.
My target device is S32K144 and I am using a GBD SEGGER J-Link Debugging line to SWD.
I have enable semihosting as you suggested but no print showing .
here
after build and flash no results .
Did you switched to semihosting console? On your screenshot is shown debugger console:
I have switch to the console but no results yet. just to let you know I'm using a JTAG 20pin connection.
