I have written a driver to program a S32K118 device and now I can program the program flash, but when I write to the FlexNVm address (0x1000000) as I program the program flash, I get an error while reading FTFE_FSTAT .
Can someone tell me what is the sequence to program flexNVM? (used like flsh)
解決済! 解決策の投稿を見る。
Thanks your information, it's usefull.
How do I program the D-flash area once I have partitioned it?
Because the "Program Phrase" and "Program section" commands can only program 24-bit addresses, and the address of D-Flash starts from 0x10000000, which requires a 32-bit address.
Mario
now i can program the area of flexNVM but except the first 0x800 addresses
do you know why?
I discovered that 0x800 is the size of flexRAM and I always find "0x33CC6699F0F055AA" at the first address of FlexNVM (0x10000000) can this information be useful?
Mario
I haven't encountered a similar problem. In theory, there should be no data. Maybe the device has been partitioned before.
I suggest that you perform a mass erase on the device first, then partition the device, and then try to read and write to the FlexNVM area.
I found an interesting pattern, in fact I can program the first sector of flexNVM.
But once I disconnect and reconnect the power, the first sector of FlexNVM is automatically modified to the value "0x33CC6699F0F055AA" and "0xFF..."
it's wired.
Do you have any thoughts on this?
Thank
Mario
Thanks you
I already understood why.
is my problem.
already solved
If you need to use the 32kb space of flexnvm as D-Flash, you need to partition it first.
you can refer to AN11983
