Unable to flash code in S32K3X4EVB-Q172 EVK Board
918件の閲覧回数
SAI1
Hi All,
we are using S32K3X4EVB-Q172 EVK board in our product development, initially it is working fine but, when we want to flash new code in the board, we unable to flash code.
Power supply and LED lights on EVK board are in perfect condition.
2 返答(返信)
912件の閲覧回数
SAI1
It is showing Run time error 216 at 0348A5D6 and results show after code flash attached images for reference
853件の閲覧回数
danielmartynek
Hello @SAI1,
Can you try debugging (stepping) it from the reset vector?
It seems like there is a fault exception detected during the startup.
Thank you,
BR, Daniel
