When using the TJA1145AFD as a transceiver for CAN FD, The MCU chip initializes the demo using TJA1145 for S32K146.TJA1145AFD Code -- Call the StartupOperation() in the TJA1145FD_Application_Specific_Functions.c file for initialization. After initialization, the relevant status register status is as follows:
CTS bit always disable, CAN_TX is high Level, CAN_RX is low level.
How to set up to enable the CAN emitter?
Hello cjgyf,
I hope all is great with you. Thank you for using the NXP communities.
Could you please share more information about your design? I mean, what is the demo used?
David
Hello cjgyf,
Please accept my apologies for the delayed response.
Could you please review the post below? I consider it might be useful for you.
https://community.nxp.com/t5/S32K/TJA1145T-sample-code/td-p/1351583
I hope this information helps.
David
The problem has been solved, thank you for your reply.
