SPI CS Flexio Configuration
889件の閲覧回数
jaikumar81
Hello Team
Need help in controlling Flexio CS line, CS line is configured as GPIO.
SPI Flexio master is enabled on S32k148, while  SPI slave is enabled on ST HW.
We have a requirement to control the SPI slave communication based on Flexio CS line.
Such that, if CS line is only then  data from  the  S32kMaster, should be process  else treat as timeout scenario.
We are noticing that SPI CS line goes low after some delayed time.
0[04 02 14 E6 00 00 ]
010101010101010101010101010101010101010101010101010101010101010101010101010101010101010101010101010101010101010101010101010101010101010101010101010101010101010101010101010101010101010101010101010101010101010101010101000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000
04 02 14 E6 00 00 <-- Payload packet to ST from S32k148
01 <-- Chip select line status of SPI Flexiomaster
00<-- Chip select line status of SPI Flexio master after certain time.
The intended request is let CS line is low for the entire Tx(S32k -> ST) and Rx(ST -> s32k) communication is complete. Since, CS line is becoming high as soon as TX being sent.. ST device is not sending any data to master considering communication has  lost as CS made high because of timeout.
Would request your support to help us know how CS line can controlled.
Jayakumar Appari.
874件の閲覧回数
danielmartynek
Hello Jayakumar,
Where do you toggle the CS GPIO line in the code exactly?
Do you use the SDK FlexIO SPI driver?
If so, do you use blocking or non-blocking transfer functions?
If I understand the issue, it could be because you use the non-blocking functions.
