S32K144 Send By SPI Interrupt mode And receive by SPI DMA mode
fudong
Hi there,
I want to use the SPI of S32K144 to read data from the 33771 chip.send data with SIP0 By Interrupt mode , which is configured as follows:
receive data with SIP1 By DMA mode , which is configured as follows:
When I call the LPSPI_DRV_SlaveTransfer() function, the program is died.
danielmartynek
Hello @fudong,
I don't understand this use case.
The 33771 is a slave on the bus, so why do you use the S32K as a slave too?
Can you please elaborate?
Thank you,
BR, Daniel
