Currently, I have S32K3X4EVB-Q172 and I want to use this evaluation board with DEVKIT - MOTORGD. Can I use them together?
Solved! Go to Solution.
yes, you can use them together.
You will most probably need to replace some resistors (this is done normally in NXP fab for motor-GD kit)
Please refer to user guide:
https://www.nxp.com/docs/en/quick-reference-guide/DEVKIT-MOTORGD_QSG.pdf
Peter
Peter
I assume you have following board:
Schematic rev A
we recommend solder R255, R257, R2184
and unsolder R40, R37, R91, R96
best regards,
Peter
